Re: Timing light that works with MSD ignition
[Re: 375inStroke]
#3237035
06/06/24 08:16 PM
06/06/24 08:16 PM
Posts: 167 Kansas
Thelma133
Kansas
I have an msd timing light. It’s the only thing that worked on my msd unit. I don’t like the dial back units.
[Re: 375inStroke]
#3237037
06/06/24 08:45 PM
06/06/24 08:45 PM
Posts: 3,262 Md.
carnut68
Md.
I have a red Craftsman, about 10 years old, dial back, seems to work and be accurate with MSD.
America First!
[Re: Thelma133]
#3237038
06/06/24 08:51 PM
06/06/24 08:51 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The old chrome Sears/Penske/Cratsman lights work. Inductive pick up. It was same as the original MSD light. Typically they can be found on ebay.
Or the modern light MSD sells. Or a Ferret 80 if you can find one.
No dial backs.
[Re: CMcAllister]
#3237045
06/06/24 09:22 PM
06/06/24 09:22 PM
Posts: 16,555 On the run…
BloFish
On the run…
No dial backs.
as I have several of them and they all work.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 375inStroke]
#3237048
06/06/24 09:25 PM
06/06/24 09:25 PM
Posts: 4,768 Moved to N.E. Tennessee
GomangoCuda
I see many people say their old dial back Craftsman timing light works with MDS ignition. I have one, all metal, at least 20 years old, and it doesn't do anything. Works fine on other cars. [censored]? No guarantee but try hooking the light to a separate battery instead of the one in the car.
[Re: 375inStroke]
#3237093
06/07/24 09:29 AM
06/07/24 09:29 AM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I see many people say their old dial back Craftsman timing light works with MDS ignition. I have one, all metal, at least 20 years old, and it doesn't do anything. Works fine on other cars. [censored]? I bought a Flaming River light, since I also have an old dial-back Craftsman light. My complaint is it uses 2 D batteries and the light is very hard to see in the daytime.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3237130
06/07/24 11:57 AM
06/07/24 11:57 AM
Posts: 4,590 Motor City
6PKRTSE
Motor City
I have an old Craftsman dial back that works fine with MSD ignitions that I keep in the garage.
I also do have a MSD brand timing light that I keep in the trailer as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Brad_Haak]
#3237131
06/07/24 11:58 AM
06/07/24 11:58 AM
BloFish
On the run…
I see many people say their old dial back Craftsman timing light works with MDS ignition. I have one, all metal, at least 20 years old, and it doesn't do anything. Works fine on other cars. [censored]? I bought a Flaming River light, since I also have an old dial-back Craftsman light. My complaint is it uses 2 D batteries and the light is very hard to see in the daytime. I went through two of those and will not buy another!
[Re: GomangoCuda]
#3237135
06/07/24 12:02 PM
06/07/24 12:02 PM
Posts: 1,715 central il.
second 70
central il.
(No guarantee but try hooking the light to a separate battery instead of the one in the car.) [/quote]
I agree this works on any timing light I've tried it on.
[Re: Brad_Haak]
#3237137
06/07/24 12:19 PM
06/07/24 12:19 PM
GomangoCuda
I see many people say their old dial back Craftsman timing light works with MDS ignition. I have one, all metal, at least 20 years old, and it doesn't do anything. Works fine on other cars. [censored]? I bought a Flaming River light, since I also have an old dial-back Craftsman light. My complaint is it uses 2 D batteries and the light is very hard to see in the daytime. Yep a three volt light just isn't as bright as a 12 volt light but it is convenient and works with any ignition. I have an old non dial back Penske light if I need it. Ever notice that no matter how carefully you put your 12 volt light away, when you take it back out the wires are always all tangled up? How does that happen?
[Re: GomangoCuda]
#3237169
06/07/24 04:36 PM
06/07/24 04:36 PM
Brad_Haak
Loudoun County, VA
[Re: Brad_Haak]
#3237171
06/07/24 04:44 PM
06/07/24 04:44 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Trust me when I tell you………that when a dial back light starts showing erroneous readings…….it doesn’t give you any indication it’s doing so.
[Re: GomangoCuda]
#3237185
06/07/24 06:42 PM
06/07/24 06:42 PM
Posts: 22,783 Bitopia
jcc
Bitopia
Ever notice that no matter how carefully you put your 12 volt light away, when you take it back out the wires are always all tangled up? How does that happen? Improper mindset. Think, "When I put it away with neat, coiled wires, I want these wires to become so intertwined and tangled that anybody that attempts to steal it, will be so frustrated they will return it right back where they found it". Works every time for me.
[Re: jcc]
#3237204
06/07/24 09:28 PM
06/07/24 09:28 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
MSD does a 12 volt light 8992 and they also have a light that uses 6 AAA batteries 8991. Haven't used the battery powered one to compare. These lights look just like the old Ferret lights that were (are) considered the best and these or the MSDs are the ones most usually seen in pro pits and engine shops. Also claimed to still be made in USA. Would not be surprised if Ferret still makes these for MSD.
MSD has always said dial back lights do not like multi spark ignitions. Most race engines use a fully degreed balancer, have the base timing locked out and timing set at idle. No need.
Trying to set full timing with a stock balancer, the engine reved up to 3k+, and dialing the mark back to line up with zero is not accurate as the electronics in the light fall behind resulting in false readings. As per an MSD tech long ago.
[Re: CMcAllister]
#3237232
06/08/24 12:06 AM
06/08/24 12:06 AM
GomangoCuda
Gxt the parent company of Ferret went out of business in 2017. I wonder if anyone bought the timing light part of their business.
[Re: fast68plymouth]
#3237233
06/08/24 12:12 AM
06/08/24 12:12 AM
GomangoCuda
Trust me when I tell you………that when a dial back light starts showing erroneous readings…….it doesn’t give you any indication it’s doing so. Many years ago I borrowed an expensive dial back light. It didn't agree with my non dial back Penske so I just handed it back and never felt the need to try another one.
[Re: GomangoCuda]
#3237236
06/08/24 12:47 AM
06/08/24 12:47 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Gxt the parent company of Ferret went out of business in 2017. I wonder if anyone bought the timing light part of their business. Looks like a Ferret 80 to me. On ebay right now... I have one of these I bought like 45 years ago. Still works perfect. Bright.
