Differential problem?
#3236936
06/06/24 08:29 AM
06/06/24 08:29 AM
Posts: 106 Norway
cudaerik
Norway
What could couse this to happed? After 12.000 street miles, no race with slicks, smallblock 340,8 3/4" clutch type sure grip.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Differential problem?
[Re: cudaerik]
#3236952
06/06/24 10:04 AM
06/06/24 10:04 AM
Posts: 4,806 Moved to N.E. Tennessee
GomangoCuda
I think the bearing seized. Zooming in to the bearing I see rust. Zooming in to the adjuster it looks like the outer race spun.
[Re: cudaerik]
#3237052
06/06/24 09:36 PM
06/06/24 09:36 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
That doesn't look like a factory Dana/spicer suregrip , what brand is it ?
Mainstream Media is the new Pravda
[Re: GomangoCuda]
#3237085
06/07/24 06:20 AM
06/07/24 06:20 AM
Posts: 106 Norway
cudaerik
Norway
I think the bearing seized. Zooming in to the bearing I see rust. Zooming in to the adjuster it looks like the outer race spun. The pictures are not the best resolution but the bearings spins freely and I do not see any wear on the bearings.
[Re: GomangoCuda]
#3237088
06/07/24 07:54 AM
06/07/24 07:54 AM
JohnRR
A gulag near you.
Not what I was expecting to see , I'd definitely be talking to Cass to figure out how that could happen.
