Re: Preferred small block intake manifold gasket kit
[Re: topside]
#3236675
06/04/24 12:18 PM
06/04/24 12:18 PM
Posts: 19,700 north of coder
moparx
Fel-Pro # MS90109 is what I used on my current 340 with J heads. For the china walls, I prefer a healthy bead of silicone, no pins or gaskets. That method seals better & lasts. i agree on the china wall sealing. those pins, at times, can cause the intake to sit high, thus resulting in vacuum leaks. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: topside]
#3236706
06/04/24 03:58 PM
06/04/24 03:58 PM
Posts: 26,029 United Socialist States of Ame...
tboomer
Thanks guys! I used Greg's gaskets in my Dominator carb when I was racing. Pretty good gaskets. So I don't have to use any factory dowel pins for installation?
[Re: tboomer]
#3236720
06/04/24 07:39 PM
06/04/24 07:39 PM
Posts: 1,770 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
FelPro Printoseal 1213S-3or Mr.Gasket UltraSeal 5840Both worked great, never used anything between the ports, just the front and rear strips between the block and intake.
[Re: volaredon]
#3236744
06/04/24 10:25 PM
06/04/24 10:25 PM
Posts: 15,567 Omaha Ne
TJP
Omaha Ne
Why don't I have luck sealing China walls the Chevy way like posters in this thread above suggests? Using the included Cork gaskets always seems to do a better job for me with RTV ONLY in the corners Possibly cleanliness. I was taught many years ago about adhesives and cleanliness. Cost me 10.00 for that bet / lesson in 1977 🤑🤑. Clean clean clean. Wipe down with acetone or equivalent and clean paper towel that must stay clean after the wipe down. Follow up with another towel and alcohol on all surfaces you're using the sealant on. Wait a minimum of 24 hours before starting the motor or putting the item to use ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#3236836
06/05/24 03:43 PM
06/05/24 03:43 PM
TJP
Omaha Ne
Why don't I have luck sealing China walls the Chevy way like posters in this thread above suggests? Using the included Cork gaskets always seems to do a better job for me with RTV ONLY in the corners Possibly cleanliness. I was taught many years ago about adhesives and cleanliness. Cost me 10.00 for that bet / lesson in 1977 🤑🤑. Clean clean clean. Wipe down with acetone or equivalent and clean paper towel that must stay clean after the wipe down. Follow up with another towel and alcohol on all surfaces you're using the sealant on. Wait a minimum of 24 hours before starting the motor or putting the item to use the "cleanliness is next to Godliness" quote comes to mind. 👍🏻 or Military boot camp clean 🤣🤣🤣
