Re: 2003 dakota 3.9 to 5.2 carb and 46rh
[Re: merpar]
#3236606
06/03/24 10:18 PM
06/03/24 10:18 PM
Posts: 10,668 Freeport IL USA
poorboy
Freeport IL USA
I'm swapping my guttles 3.9 for a 5.2 stroked to 390 with Speed master heads. swapping 42re to a 46rh. Running holley 650 spread bore. trying to eliminate as much electronics as possible, plan to use stock in tank fuel pump with bypass. Does anyone know of any problems I may encounter? I don't see an ignition system mentioned. And I presume you are intending on installing aftermarket gauges and speedo? If you intend to eliminate the ecm, you need to eliminate everything connected to it. That includes all the switches on or under the dash that uses the trucks buss bar resistance electronics.
[Re: merpar]
#3236679
06/04/24 12:43 PM
06/04/24 12:43 PM
poorboy
Freeport IL USA
I went with a 5/8 bypass hose. I've gone with the magnum accessories fixture, lots of fab work but have generator, air compressor, steering pump, idler pulley and adjusting unit. And I'm on my third serpentine belt trying to get the right length. Only bad thing about that is I live about 30 miles from town. For ignition am running an old stock new Mallory distributor. Haven't gotten into all the electrical yet. Biggest problem I have is time. I'll be 81 next week and would like to finish this project soon enough to enjoy it for a while. I've learned that drag racing and street rods are a terminal illness. Once you catch it you can't get rid of it. Rewiring your 03 truck will be a pain, but an aftermarket wiring harness, and eliminating the original harness may be the fastest and easiest way to solve a bunch of problems you are going to find. Splicing two completely different wire harnesses together can get complicated really quickly, go with one (OEM system) or the other (full aftermarket). There are several wiring "kits" out there that are good stuff at less expense then the above suggested name brand, Rebel Wiring comes to mind. What you need to do is decide how many of those special features your 03 truck has that you just "need" to keep functioning and how may you can eliminate. The more back to the basics you go, the easier it will be to make everything work. Not very complicated to make it run, charge the battery, and run the headlights, tail lights, turn, and brake lights. A few simple accessories are not such a big deal t add, but every extra makes it more complicated.
[Re: merpar]
#3236702
06/04/24 02:51 PM
06/04/24 02:51 PM
Posts: 2,745 541 slobovia
A990
541 slobovia
And I'm on my third serpentine belt trying to get the right length. Weedeater string works good here. If using the spring tensioner, look close, theres usually a safety range marking that is useful for targeting the belt length needed.
