4 spd lever nuts #323593
05/20/09 01:29 PM
05/20/09 01:29 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Should 71 18 spline 4 spd lever nuts be clear zinc or black phosphate ?
logan426
Re: 4 spd lever nuts [Re: MLR426] #323594
05/20/09 02:58 PM
05/20/09 02:58 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
5/16-24 ( fine thread) flange lock nut - black phosphate
Re: 4 spd lever nuts [Re: gtx6970] #323595
05/20/09 03:00 PM
05/20/09 03:00 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
That's what I used and was hoping it was correct,
thank Bill.
Logan426 Martin
Re: 4 spd lever nuts [Re: MLR426] #323596
05/20/09 08:18 PM
05/20/09 08:18 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Could you please post a pic? Thank you.
Re: 4 spd lever nuts [Re: rayztoy] #323597
05/20/09 08:28 PM
05/20/09 08:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 4 spd lever nuts [Re: gtx6970] #323598
05/21/09 08:11 AM
05/21/09 08:11 AM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
I picked mine up at a local farm store, in the Serve O Lite nut and bolt section.
logan426
Re: 4 spd lever nuts [Re: MLR426] #323599
01/25/10 12:25 PM
01/25/10 12:25 PM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
Are these used with any washers or lock washers, I can't seem to find any info. My parts book illustrates washers, but does not list any part numbers.
Re: 4 spd lever nuts [Re: myrddin] #323600
01/25/10 01:45 PM
01/25/10 01:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No washer as the flange spreads the load.. No need for a lock washer as the nut is self locking... If you look closely at the picture you'll see the last thread is intentionally distorted to create a locking effect...
