Dash lights #3235766
05/30/24 11:43 PM
05/30/24 11:43 PM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
Not really a big deal but curious...(1970 ralley dash -roadrunner)
I noticed when I scroll my dome light on at the light switch the gauge light get just a touch bit brighter. When I turn my dome light off at the switch the gauge lights get a bit dimmer. Is this normal?
Thanks in advance
Re: Dash lights [Re: Roadrunner440-6] #3235841
05/31/24 10:38 AM
05/31/24 10:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks in advance
The function of the dimmer switch is to control the brightness of the IP lights. That it also controls the courtesy lights is a secondary function.
"Breathlessly waiting for the next pearl of wisdom from the massive intellect of DaveRS23."
Re: Dash lights [Re: 6PakBee] #3235847
05/31/24 10:50 AM
05/31/24 10:50 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yes, the switch progressively brightens the IP lighting as you turn it, and at max position, turns on the dome light(s).
At minimum position, instrument lighting will be very low or essentially off.
If there's not much change in IP illumination, it's likely to be the normal corrosion of contact mechanism.
Those thumbwheels have been prone to poor dimming operation for decades.
IIRC, there are repops available for Charger Rally cluster, but it could just need cleaning.
Maybe try squirting some aerosol contact cleaner in there.
