Throttle cable bracket #3235661
05/30/24 02:24 PM
05/30/24 02:24 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Does anyone know if there is anyone who sells a throttle cable bracket for a high rise intake on a B motor that gives you the ability to adjust the position of the clamp that secures the throttle cable? Preferably, a bracket that looks similar to a MP or Mancini bracket that somewhat resembles a factory bracket rather than the Lokar type brackets.
Re: Throttle cable bracket [Re: 6PAX] #3235666
05/30/24 03:01 PM
05/30/24 03:01 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I used this one from Jegs, Worked good for a taller intake. https://www.jegs.com/i/JEGS/555/15154/10002/-1
The only Carbs I care about are under the hood!
Re: Throttle cable bracket [Re: 6PAX] #3235670
05/30/24 03:17 PM
05/30/24 03:17 PM
AndyF Offline
AndyF  Offline
The tall brackets I sell allow you to rotate the top part to get the correct angle. The throttle cable also has some adjustment on where you clamp it.
https://arengineering.com/home-page/throttle-bracket-kits
Re: Throttle cable bracket [Re: AndyF] #3235690
05/30/24 05:36 PM
05/30/24 05:36 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Amazon less than 30 bucks..
Re: Throttle cable bracket [Re: B1MAXX] #3235697
05/30/24 05:45 PM
05/30/24 05:45 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've used Andy's brackets on a couple engines, and they work fine.
On the most recent deal (340 w/AirGap, no kickdown) we just measured for a while and fabbed a 1-piece.
Ran concentric return springs from bottom of carb throttle arm back to the bracket, gets them out of the way & I think it's tidier.
