How much air is that "scooping"?
As you know only too well not everything is always as it appears. It might flow a bit and it is one of two OEM Pontiac formula hood scoops so must have done something at one time
BUT it's really not there for air flow it is there for air cleaner clearance. The '56 has the Dakota front frame clip with a Z'ed frame at the join and that lowers the body but the Dakota clip stays at stock height.
The fuel injected 318 motor mounts had to be moved rearward which also required raising the engine a bit. Al the things contributed to the hood hitting the air cleaner. Thanks for asking.
![[Linked Image]](https://i.imgur.com/ly39QR6.jpg)
