B&M 10238
[Re: moparts]
#3224159
04/01/24 08:24 AM
04/01/24 08:24 AM
Posts: 43 MI, Livingston
plymth70
MI, Livingston
Need a B&M 10238 flex plate for a 1970 440-6 external balance motor. Need for balancing rotating assy. Could use fly wheel instead. Problem solved. Thank you Brewer's Performance
Re: Mopar Transmission Wanted - 2nd Quarter
[Re: moparts]
#3224426
04/02/24 06:39 AM
04/02/24 06:39 AM
Posts: 5,665 Detroit area
6PAX
Detroit area
Wanted:
Turbo Action 17676 automatic/manual valve body for 727
Big block 727 bellcrank to transmission kickdown lever linkage rod. Doesn't have to have quite the same bend in it as shown in the picture but the length needs to be the same as well as the ends where it attaches to the bellcrank and trans. lever. The rod shown is from a 67 GTX.
I'm also looking for one of these aftermarket Mopar logo shifter balls. Black ball with white Mopar logo (blue logo O.K. too). I know they are available new but I don't want to spend that much so I am good with a used one.
gt340 at yahoo.com
