2012 Ram 1500, Flexplate cracks ??? common? #3234003
05/20/24 05:53 PM
05/20/24 05:53 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I am getting a light squeaky sound in my truck, But 2000 miles from home
Sure sounds like its back of the engine, front of the trans area. No oil lights / pressure problems. Trans shifts normal.
I first noticed it mid Texas area. Drove another 800-900 miles with no issues. Noise didnt get any better, or did it get any worst
It has a squeak sound sure sounds like a flexplate. Pulled the lower brace to see up in the back of the crank flange area. Cant say that i can see anything obvious .
But it sure sounds like thats the problem.
Anyone had a similar issue ,,,,, is this common ?
Re: 2012 Ram 1500, Flexplate cracks ??? common? [Re: gtx6970] #3234013
05/20/24 07:28 PM
05/20/24 07:28 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Any cracked flexplate I've ever encountered(turned wrenches my whole life) made a LOT more noise than a squeak. twocents
Re: 2012 Ram 1500, Flexplate cracks ??? common? [Re: Dcuda69] #3234027
05/20/24 09:02 PM
05/20/24 09:02 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
It has a mixture of a squeak / chirp noise. how loud it is changes / Comes and go.
Diminishes ever so slightly once in gear and power braked to a degree
Ive had some GM cars with a cracked plate. But never a Mopar , ever
Re: 2012 Ram 1500, Flexplate cracks ??? common? [Re: gtx6970] #3234030
05/20/24 09:20 PM
05/20/24 09:20 PM
A727Tflite Offline
A727Tflite  Offline
Likely the plate. They start to squeak. Then things get worse. Just had a 2017 diesel - same issue.
