Re: oil dispenser "lubester"
[Re: burdar]
#3233954
05/20/24 02:12 PM
05/20/24 02:12 PM
Posts: 1,238 Chicago, IL
PLUM_72
Chicago, IL
Those are cool! I have seen restorations where some have cut a large opening in the front panel, and then made shelves on the inside to display oil cans or other gas/oil related collectibles. If you want to get heavily into this stuff, start with oldgas.com You'll find information there as well as places to buy items such as decals etc for the restoration. Enjoy!
1972 Dodge Challenger
[Re: PLUM_72]
#3234012
05/20/24 06:50 PM
05/20/24 06:50 PM
Posts: 11,421 NJ
rdrnr6970
Your #1 source for current events
NJ
Never used them,I've noticed restored ones showing up on Mecum auctions and they look cool!
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
[Re: burdar]
#3234024
05/20/24 08:57 PM
05/20/24 08:57 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I worked for more than one service station in SO CA in the late 1950s and early to mid 1960 that had those containers, usually five or six of them full of different oils and other lubes. I'm not sure when they started to be discontinued, each lube bay would usually have one air powered grease gun and rear end gear oil dispenser with a resettable dial on the gear oil gun for charging the customers for how much gear oil we would use to bring their rear ends up to the full level after each use I think those pumps were hook up to either a 30 gallon or 55 gallon barrels stored in the back rooms For the life of me I can't remember ever seeing anyone refill those oil containers in the lube bays
[Re: TJP]
#3234055
05/20/24 11:47 PM
05/20/24 11:47 PM
Posts: 1,844 South Bend
John Brown
South Bend
I worked at a Sinclair station until 1969 and a Shell in 1970 and we sold bulk oil like that daily.
