Trickflow 240 rocker arm question #3233563
05/18/24 03:26 PM
05/18/24 03:26 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
I am building a 512 stroker with trick flow 240 heads. I am aware of the specific redesigned trickflow specific rocker arms harland sharp makes, but...backordered. i am trying to get the car buttoned up in the next 2 weeks.
Are there any other rocker arms that work good with this setup? The pattern ia definately off to the side more than I like, but I may just have to run them if I cant find anything quick enough. Has anyone else found another option other than the specific trickflow rockers by Hs?
Re: Trickflow 240 rocker arm question [Re: moparguy] #3233565
05/18/24 03:37 PM
05/18/24 03:37 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I seem to remember someone saying Comp and Hughes rockers work ok.
Re: Trickflow 240 rocker arm question [Re: moparguy] #3233574
05/18/24 04:53 PM
05/18/24 04:53 PM
sweden
carter Offline
carter  Offline
sweden
Crane Gold rockers if you find a set.
Re: Trickflow 240 rocker arm question [Re: carter] #3233577
05/18/24 05:08 PM
05/18/24 05:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It wouldn’t bother me a bit to run this-
Re: Trickflow 240 rocker arm question [Re: moparguy] #3233746
05/19/24 03:54 PM
05/19/24 03:54 PM
AndyF Offline
AndyF  Offline
I tested a bunch of rocker arms on TF240 heads when they first came out. https://www.motortrend.com/articles/trying-find-extra-power-rocker-arm-testing/
I don't see a big problem with what you show in the picture. Use a felt pen to color the end of the valve and then push it thru a couple of cycles and see what the wear pattern looks like. It will probably look okay.
