Re: Car guru's wiring Q?
[Re: Dragula]
#3233313
05/17/24 11:41 AM
05/17/24 11:41 AM
Posts: 721 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Metripack 280, water tight and good for 30 amps continuous.
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3233330
05/17/24 12:52 PM
05/17/24 12:52 PM
Posts: 19,522 Las Vegas
Al_Alguire
Las Vegas
All I use is Duetsch connectors these days, or Milspec bulkhead connectors. It costs more but NEVER had an issue. Also a HUGE fan of floating ground systems.
[Re: Dragula]
#3233487
05/18/24 09:48 AM
05/18/24 09:48 AM
Posts: 893 Missouri
jwb123
Missouri
As mentioned, any high current device will benefit from a relay to carry the load. If you are carrying enough amperage to melt connections then either the device is drawing too much amperage, wire size is not big enough, or maybe a grounding issue. I solder and heat shrink all my connections, and any plug-in connectors have to be designed for the amperage involved. Many years ago, I bought a small block Vega, and my first race I was in the finals, lost because car would not fire due to corroded wiring connections, after that I was very careful of wiring, cost me $1,000 purse.
[Re: Dragula]
#3233593
05/18/24 07:49 PM
05/18/24 07:49 PM
Posts: 12,250 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Honestly, I would be looking for a different fan set up. I've used all kinds of fans - dual set ups, big, little 10 or 12 amps is plenty. No idea how you get to where you are.
[Re: Dragula]
#3233644
05/19/24 06:21 AM
05/19/24 06:21 AM
Posts: 5,982 Greenville, PA
redraptor
Greenville, PA
So I am switching to 10ga wire and probably Deans plugs for those, but figured I would ask.
That should cure it. 35 FLA is too much for # 12 and 20A is about max, I just went thru this with a buddy's Derale set up.
