Re: valve body interchange ?
[Re: calrobb2000]
#3233137
05/16/24 11:43 AM
05/16/24 11:43 AM
Posts: 25,955 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The big change in '71 was in the area of the accumulator, swapping the '71-later VB into a pre-'71 eliminates part of the accumulator's function...it'll work but it would be better to just swap the PTK module onto the early VB as JohnRR suggested..
[Re: JohnRR]
#3233152
05/16/24 12:23 PM
05/16/24 12:23 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I believe you can just move the PTK assembly to the other VB , but yes you can also swap over the VB . What is a "PTK"?
[Re: Cab_Burge]
#3233157
05/16/24 12:50 PM
05/16/24 12:50 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
I believe you can just move the PTK assembly to the other VB , but yes you can also swap over the VB . What is a "PTK"? Part throttle kick down?
[Re: GODSCOUNTRY340]
#3233245
05/16/24 11:15 PM
05/16/24 11:15 PM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
I believe you can just move the PTK assembly to the other VB , but yes you can also swap over the VB . What is a "PTK"? Part throttle kick down? 🎯👍
[Re: Cab_Burge]
#3233263
05/17/24 03:54 AM
05/17/24 03:54 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
I thought the later ptkd wont fit the early vb? You’d need an early 6 cly one to fit the early trans? A and A sells the early version.
I want my fair share
[Re: SomeCarGuy]
#3233264
05/17/24 03:57 AM
05/17/24 03:57 AM
SomeCarGuy
http://www.aandatrans.com/Products/727-3-2-Kick-Down-Module-(1966-69)__22740-32SI.aspx
Here it is. Says you can’t switch between styles
[Re: John_Kunkel]
#3233286
05/17/24 09:20 AM
05/17/24 09:20 AM
Posts: 9,871 MI, usa
dvw
MI, usa
The big change in '71 was in the area of the accumulator, swapping the '71-later VB into a pre-'71 eliminates part of the accumulator's function...it'll work but it would be better to just swap the PTK module onto the early VB as JohnRR suggested.. John could you go into more detail on the change in the accumulator function? Doug
[Re: dvw]
#3233333
05/17/24 12:56 PM
05/17/24 12:56 PM
John_Kunkel
Rio Linda, CA
The big change in '71 was in the area of the accumulator, swapping the '71-later VB into a pre-'71 eliminates part of the accumulator's function...it'll work but it would be better to just swap the PTK module onto the early VB as JohnRR suggested.. John could you go into more detail on the change in the accumulator function? Doug On the pre-'71 the accumulator piston has fluid pressure bearing on only two surfaces. In '71 they added the 1-2 Shift Control Valve which sends fluid pressure to a third surface of the piston. Basically, the early accumulator would cushion the 1-2 upshift the same at all throttle settings where the later cushions the 1-2 upshift depending on the throttle setting. To make this change, they added another fluid passage to the case, so when swapping VB's, all the fluid ports don't line up correctly. The difference in the PTK modules is the addition of a limit valve in the later module that limits PTK to about 40 mph and below. With the early module it would still kickdown at higher speeds depending on the axle ratio.
