Under ground tank explosion... #3231453
05/06/24 07:12 PM
05/06/24 07:12 PM
Star Idaho
67vertman Offline OP
Star Idaho
what would cause this? looks to be in an Arabic country.
My Monster are real!
Living within your means makes life pretty easy.
Re: Under ground tank explosion... [Re: 67vertman] #3231456
05/06/24 07:25 PM
05/06/24 07:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't know, but the person peelin' out without removing the filler nozzle was pretty funny...
Re: Under ground tank explosion... [Re: 67vertman] #3231457
05/06/24 07:28 PM
05/06/24 07:28 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
You gotta have both fuel, and an oxidizer (usually air). If either is missing, no big badda boom.
Re: Under ground tank explosion... [Re: 67vertman] #3231464
05/06/24 08:03 PM
05/06/24 08:03 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
They probably have real gas...not the goat pee that we are forced to use. twocents
Re: Under ground tank explosion... [Re: Hugh Jorgan] #3231467
05/06/24 08:12 PM
05/06/24 08:12 PM
Star Idaho
Star Idaho
haha hammer
Yes, my parents owned a service station in the late 50s early 6os and the gas back then was a much higher octane blend.
Re: Under ground tank explosion... [Re: topside] #3231468
05/06/24 08:12 PM
05/06/24 08:12 PM
Star Idaho
Star Idaho
Re: Under ground tank explosion... [Re: 67vertman] #3231540
05/07/24 10:23 AM
05/07/24 10:23 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
It's scary, but the underground tank setup did its job. The explosion was contained.
Re: Under ground tank explosion... [Re: 67vertman] #3231664
05/08/24 12:51 AM
05/08/24 12:51 AM
I wonder if one of the tanks was near or almost completely empty allowing air to be pump up to the pumps and hoses allowing static electricity to flow back into that tank causing the explosion.? work
Full tanks don't explode like that, half empty or less will shruggy
Re: Under ground tank explosion... [Re: Cab_Burge] #3231799
05/08/24 06:21 PM
05/08/24 06:21 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Towel head bomb. Just a normal typical day.
Re: Under ground tank explosion... [Re: 67vertman] #3231801
05/08/24 06:24 PM
05/08/24 06:24 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
Probably some Hadji trying to keep up to date on his IED skills! tsk
Re: Under ground tank explosion... [Re: JDMopar] #3232152
05/11/24 10:13 AM
05/11/24 10:13 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
The no smoking sign is there for this reason!
Re: Under ground tank explosion... [Re: 67vertman] #3232404
05/12/24 09:35 PM
05/12/24 09:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
[quote=67vertman]what would cause this? looks to be in an Arabic country. [quote]
Like Dearborn?
Re: Under ground tank explosion... [Re: J_BODY] #3232410
05/12/24 09:54 PM
05/12/24 09:54 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Hory sheit!
Re: Under ground tank explosion... [Re: Sunroofcuda] #3232544
05/13/24 01:38 PM
05/13/24 01:38 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Given the flame, coupled with lack of post-explosion burn, I'm thinking an improperly vented waste tank of some sort. A build-up of methane gas sparked by an automatic transfer pump, maybe?
Re: Under ground tank explosion... [Re: J_BODY] #3232552
05/13/24 02:11 PM
05/13/24 02:11 PM
Star Idaho
Star Idaho
Like Dearborn?
And a few other areas as well. flame
