Re: Terminal ends for efi components.
[Re: AndyF]
#3232076
05/10/24 03:50 PM
05/10/24 03:50 PM
Posts: 836 Missouri
galen
Missouri
First check out the Holley wiring store. They have connectors, pins, crimpers, etc. If you can't find what you need there then search Amazon (or Google) for Metripak kits and crimpers.
Not all of the connectors are Metripak, Holley uses mostly GM components and GM uses whatever fits, works and is cheap. So you'll find all sorts of weird stuff in a Holley EFI harness. Thanks Andy. It does look like some of the gm stuff is weatherpack also.
[Re: AndyF]
#3232137
05/11/24 08:45 AM
05/11/24 08:45 AM
Posts: 1,008 rust belt
Moparite
rust belt
Automotive plugs can be made from various manufactures. Some will have a # and the manufacture name and you can look it up that way. As you see here you have to kind of know what you are searching for.
[Re: jbc426]
#3232183
05/11/24 12:34 PM
05/11/24 12:34 PM
Posts: 6,306 nowhere
Sniper
nowhere
This is who I use for my connector parts. They list the sensor and the parts needed to connect to it. All quality stuff https://www.bmotorsports.com/shop/index.php/cPath/129If you know the GM part number you can search that way, or the aftermarket part number, usually. Same the injectors or just about any other EFI part
