Page 2 of 3 1 2 3
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225360
04/06/24 09:00 AM
04/06/24 09:00 AM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by AndyF
Yes, his carb needs to be reworked. It is a 3 circuit Holley that hasn't been modified and the intermediate circuit floods the engine at certain throttle positions. Evidently it runs okay from him at the track because of his two step and then being WOT down the track, but it was super rich on the dyno when we were trying to start the pulls. But the engine showed some signs of being run rich so we told him to either buy a two circuit, or to get someone to rework his carb.
The dyno carb is a box stock Holley 1050 XP. It works great on every engine we use it on. Usually don't even need to change jets in it.
I had problems footbraking 3 circuit Dominators, and always converted them to 2 circuit. Not that big of a deal to do.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Low deck Indy 540 on the dyno [Re: moparacer] #3225370
04/06/24 09:45 AM
04/06/24 09:45 AM
gregsdart Offline
gregsdart  Offline
Things that come to mind are what rocker ratio, the lash amount and intensity of rhe cam, thickness of the rings, and the effect of the intake/adapter combo, and how much room for improvement there might be in those areas?
My first 440-1 build after porting the heads made over 840 hp with a similar cam but injected methanol. So i bet the things i mentioned may be holding it back from 850 hp.
Re: Low deck Indy 540 on the dyno [Re: gregsdart] #3225387
04/06/24 11:08 AM
04/06/24 11:08 AM
AndyF Offline OP
AndyF  Offline OP
I don't think it would require much work to bump this engine up to 850 hp but the owner didn't seem interested. The engine goes in a pickup that he drag races and he runs low 9's or high 8's and is happy with it.
From what I've seen over the years only about 5% of the customers are actually interested in finding more power after a dyno session. Most customers just want to get the engine home so they can put it in the car and get back to racing.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225395
04/06/24 11:28 AM
04/06/24 11:28 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Did you guys do any work on that engine…….or was it just there for a dyno test?
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225420
04/06/24 01:30 PM
04/06/24 01:30 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Is it just me or are those dyno headers kind of small for 850-900 hp?
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225437
04/06/24 03:03 PM
04/06/24 03:03 PM
NC
440Jim Offline
440Jim  Offline
NC
Did the owner at least have a few ignition timing settings tested?
The combination 4150 intake with carb adapter to 4500 may have limited top rpm power capability at 540 CID.
It would be interesting to see how the HP held up past peak. It might benefit from a higher shift point.
Re: Low deck Indy 540 on the dyno [Re: 440Jim] #3225441
04/06/24 03:16 PM
04/06/24 03:16 PM
AndyF Offline OP
AndyF  Offline OP
That is a good point. The 4150 to 4500 trick might work great on a 440 to 500 inch engine but not so great at 540 inches. I tested it on my 514 and the best intake for that engine was a 4500 intake. The Super Victor worked best for me. The 440-3 was okay, the 440-3x didn't make more power.
I think all runs were made at 35 degrees. I don't recall changing the timing on it.
Re: Low deck Indy 540 on the dyno [Re: fast68plymouth] #3225444
04/06/24 03:26 PM
04/06/24 03:26 PM
AndyF Offline OP
AndyF  Offline OP
It got rings and bearings, upgraded to a belt drive, fixed some issues. I think the short block was built by Indy originally but I might be wrong.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3225742
04/08/24 09:25 AM
04/08/24 09:25 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Most customers don't want to spend the extra dyno money. Also, there is zero reason to test stuff that doesn't fit the car. Why test carb spacers, if you don't have room for them? What good are dyno headers if they don't fit your chassis, other than they fit the dyno?
69 GTX 68 Road Runner
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3230855
05/03/24 06:04 PM
05/03/24 06:04 PM
AndyF Offline OP
AndyF  Offline OP
Just for comparison, had a Chevy 540 on the dyno today and it made 920 hp. Very similar engine to the 540 Mopar. This BBC is also all aluminum, similar compression, similar cam specs, single 4 bbl intake using the same 1050 dyno carb, both were wet sump with vacuum pump, both used dyno headers, both use Jesel belt drive, crank trigger with MSD, etc. The BBC heads are just that much better. This engine uses Brodix Big Brodie 3x heads. I think they are 365 cc with a big rectangular intake port. The intake port is so big it requires a special gasket and you have to buy the Brodix intake if want it to fit out of the box.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3230888
05/03/24 09:09 PM
05/03/24 09:09 PM
SoCal
Brian Hafliger Offline
SoCal
Those BB3 Heads are no joke! Brodix moved the valves around some (still 24°) to accommodate a larger valve without shrouding...they make power!
Brian Hafliger
Re: Low deck Indy 540 on the dyno [Re: Brian Hafliger] #3230896
05/03/24 10:28 PM
05/03/24 10:28 PM
AndyF Offline OP
AndyF  Offline OP
This is the first time I'd seen these heads. I figured the engine would make 850 hp since the compression wasn't that high and the cam was an off brand. But when we opened the throttle the engine started to howl and the needle spun on the HP gauge.
Funny thing about this engine is that the customer who brought it in bought it at the track from a guy who was pissed at poor performance. Guy was so mad he sold the engine for $10K at the track. Probably cost close to $40K to build an engine like this with all new parts.
We didn't have the heads off the engine so I wasn't able to look them over carefully. The Brodix website says the 366 cc version flow 423 cfm @ 0.800 lift. The 380 cc version flows 440 cfm. I think this engine has the 366 cc version since the ends of the heads are stamped 366. But there isn't any other information on the heads so I'm not sure if that is a cc stamp, or if it some random date stamp or foundry mark.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3230904
05/03/24 11:00 PM
05/03/24 11:00 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Anyone know what a Ray Barton Hemi would cost? And what power they make
Re: Low deck Indy 540 on the dyno [Re: MoonshineMattK] #3230915
05/04/24 12:18 AM
05/04/24 12:18 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Years ago, there was a 'Cuda local to here that had a BBC in it, people gave the owner a hard time about it. At a car show a few of us were looking at it and some were not pleased with the swap, the guy's wife or his GF, not sure which, said something like, we wanted to go fast but had enough money to build a car or just build an engine.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3231115
05/05/24 10:28 AM
05/05/24 10:28 AM
PA
moparacer Offline
moparacer  Offline
PA
Not the first time I have seen or heard of 900+ hp BBC motors that are not running ET's according to weight and HP.
I drove one last year that was 900 hp and 300 lbs lighter than my crate and ran the exact same ET. shruggy
Sometimes big honking carbs, intakes heads and header pipes and dyno numbers don't equate to quick ETS at the track.
Made a lot of noise though! laugh2
Re: Low deck Indy 540 on the dyno [Re: moparacer] #3231132
05/05/24 12:02 PM
05/05/24 12:02 PM
AndyF Offline OP
AndyF  Offline OP
I'm not sure exactly what the previous owner was upset about but the current owner is going to be happy at the track. He has a Monte Carlo that currently runs in the nines with a 780 hp big block. This engine will be a little lighter due to the aluminum block, and it has 140 more hp. He runs in a 9.00 to 10.50 bracket class and he wants to have the most MPH at the stripe so he is stepping up to this engine.
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3231231
05/05/24 08:14 PM
05/05/24 08:14 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
A BBF that is similar would probably make more again. I don't know what the Chrysler engineers were thinking when they designed the BBM factory heads, but it wasn't performance. Even a lot of the aftermarket stuff isn't great, compared to their Ford and GM counterparts.
Alan Jones
Re: Low deck Indy 540 on the dyno [Re: LA360] #3231241
05/05/24 09:04 PM
05/05/24 09:04 PM
AndyF Offline OP
AndyF  Offline OP
Maybe, depends on the Ford and the heads. FE Fords don't make a lot power, but the 385 series can make big power. I have a 521 Ford with Kaase heads that is ready to go on the dyno. I think it will make around 850 hp. The heads can make a lot more power but there aren't really good intakes available for that engine. Kaase has built some bigger SR-71 engines that make a ton of power so it can be done.
The Mopar BB is basically a truck engine. That is why it has the tall deck, tall pistons, heavy skirt, tiny ports, etc. The Mopar engineers could've built a low deck 451 or 470 with MW heads back in the early 70's and kicked Chevy to the curb but they didn't do it. A low deck 470 with MW heads and a big 4bbl would've been surprised a lot of street guys back in 1972!
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3231246
05/05/24 09:30 PM
05/05/24 09:30 PM
PA
moparacer Offline
moparacer  Offline
PA
I have always said Mopar should have built a 451.....
I have never owned a 440 block. My 502 is a low deck. thumbs
Re: Low deck Indy 540 on the dyno [Re: AndyF] #3231275
05/06/24 01:45 AM
05/06/24 01:45 AM
gregsdart Offline
gregsdart  Offline
Or better yet, a 500 inch low deck, with a set of modified high port max wedge heads that would accept an RB max wedge intake, preferably 2 4bbl. Add 1.7 rockers maybe? A motor like that could be built to 500 hp without breaking a sweat. And it would have TORQUE!
Page 2 of 3 1 2 3
