Re: Pushrod Oiling G2 BME Block issues [Re: Cab_Burge] #3232460
05/13/24 08:41 AM
05/13/24 08:41 AM
indianapolis, in
rt1976 Offline OP
rt1976  Offline OP
indianapolis, in
Mine is set up for pushrod oiling only
Re: Pushrod Oiling G2 BME Block issues [Re: rt1976] #3232495
05/13/24 10:23 AM
05/13/24 10:23 AM
Cab_Burge Online work
Cab_Burge  Online Work
The first pushrod oiling motor I put together I used a set of spray bar valve covers also to be safe, I ran that motor for several races and ended up removing them and saw no difference in oil pressure or top end oiling shruggy confused
I'll do the same on the next also up
