More manual trans questions #3231843
05/08/24 11:54 PM
05/08/24 11:54 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
What is the purpose / function of the shift keys and their springs in the slider assembly ?
Is it to make the slider "want" to be in the neutral gate position ?
Is it to put a little extra pressure / force on the synchros when going for engagement on the gear cone ?
Re: More manual trans questions [Re: hemienvy] #3231863
05/09/24 08:42 AM
05/09/24 08:42 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
shift keys act as detents to hold slider in neutral position, then when you start to shift, they press against the brass rings to engage the cone of the syncro, the brass ring locks onto the cone, this speeds up or slows down the gear you will shift into, so you do not grind the syncro teeth.
Re: More manual trans questions [Re: jwb123] #3231891
05/09/24 11:33 AM
05/09/24 11:33 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I believe they also hold the slider in the gear selected ?
Re: More manual trans questions [Re: JohnRR] #3231905
05/09/24 12:36 PM
05/09/24 12:36 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
X2.
Otherwise, you'd have to hold the shifter and keep the forks against the synchronizer
Angry white pureblood male
