2018 Ram rear noise #3231819
05/08/24 07:45 PM
05/08/24 07:45 PM
Indiana
dragracer1 Offline OP
Indiana
Greetings fellow moparty patrons!!
I have a 2018 Ram SLT Big Horn and it has a weird noise that comes from the rear portion of it. It does it under a load at higher rpm’s and its like a exhaust leak, but I have checked everything and all seems perfectly normal.
Any idea’s would be GREATLY appreciated!!
BP
Re: 2018 Ram rear noise [Re: dragracer1] #3231840
05/08/24 11:10 PM
05/08/24 11:10 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Check the u joints and the rearend yoke nut (pinion nut]
Re: 2018 Ram rear noise [Re: stumpy] #3231978
05/09/24 09:49 PM
05/09/24 09:49 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
At 160K miles I lost my carrier bearings in my 2015 Ram 2500. It started out as a weak howling noise then got worse. Have you had the cover off and checked them?
JB Rhinehart, Realist
A-Body's RULE!
Re: 2018 Ram rear noise [Re: Rhinodart] #3232023
05/10/24 10:11 AM
05/10/24 10:11 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yet another reason I like my 98 2500 ...
Re: 2018 Ram rear noise [Re: JohnRR] #3232030
05/10/24 10:59 AM
05/10/24 10:59 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I don't know what year they changed from the Dana 60 to the American Axle rears. I blew the rear in my 96 2500 V10 at 150K too though...
A-Body's RULE!
Re: 2018 Ram rear noise [Re: Rhinodart] #3232032
05/10/24 11:14 AM
05/10/24 11:14 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Front and rear ring and pinion were replaced on my 04 1500 under warranty. They were making noise again when I traded it in at 70k.
Re: 2018 Ram rear noise [Re: Rhinodart] #3232069
05/10/24 02:46 PM
05/10/24 02:46 PM
JohnRR Offline
JohnRR  Offline
AAM change over happened in the 2003 model year ,
You're an animal beer , I have 2 Dana 70';s , one has 230K miles in a truck I bought new. 2000 2500 4x4 , now I have the 98 2500 2wd that just rolled 212k , I bought it at 172k , unsure of history of the rear axle but it had a 5th bolted in it at one point and google earth told me the previous owner had an excavation company , but the truck still had it's factory installed shocks and exhaust system going by the date codes on them when I bought it and the rear sounds fine.
That said I had an early 2001 2500 2wd w/Dana 70 that had 328k on it when I bought it that was a farm hauling truck ... 1" thick steel plate welded across the frame rails and a gooseneck ball poking thru a hole in the bed ..., it howled when I got it and someone had changed bearings. I changed them out when I got it and the gears looked ugly, but it was a local use only for me so I just slammed in new bearings and drove it as is ... it howled less ... till I traded it in with 330K ...
Re: 2018 Ram rear noise [Re: JohnRR] #3232110
05/10/24 08:49 PM
05/10/24 08:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I vote for dropping the drive shaft and checking the tightness of the pinion nut.
While you are under there, take a look at the condition of the rubber in the transmission mount. Both have been problem areas.
