Milky oil on one cylinder rockers #3231352
05/06/24 11:46 AM
05/06/24 11:46 AM
Maine
E
exile5700 Offline OP
E
Maine
My car has sat through the Winter in an unheated garage. When I pulled the valve cover the driver side rear set of rockers are milky, none of the others are and the inside of the valve cover on that end has a milky substance. Is this because of setting all Winter or do I have an issue?
Re: Milky oil on one cylinder rockers [Re: exile5700] #3231353
05/06/24 11:50 AM
05/06/24 11:50 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Last time I saw that it was a bad head gasket. work
Re: Milky oil on one cylinder rockers [Re: exile5700] #3231354
05/06/24 11:51 AM
05/06/24 11:51 AM
Kirkland, Washington
Pacnorthcuda Offline
I would highly suspect it’s just condensation. Wipe it clean, put back together and run it. Watch the dipstick, but I bet it’s fine.
Re: Milky oil on one cylinder rockers [Re: exile5700] #3231358
05/06/24 12:03 PM
05/06/24 12:03 PM
Two things you can do to fix that, drive it long enough2 t 0 4 hour trip to get the oil temps above 160F or use something to heat the oil up in the motor or drain it and heat it up on a stove, If you heat it up on a stove be very careful that you don't have the condensation settled to the bottom of the container and then create a lot of turbulence when it turns to steam from the bottom of the container wrench up luck
Re: Milky oil on one cylinder rockers [Re: Pacnorthcuda] #3231360
05/06/24 12:06 PM
05/06/24 12:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've only seen that on one of my engines: it was fresh off the dyno, no winter or cold weather, and on both sides in the heads & valve covers.
That engine had a litany of problems, which I doubt yours has, but head gasket sealing was a possible cause.
One unpleasant discovery: the builder - Bob Lambeck - had actually milled through the valve reliefs in the pistons, about 1/4" x 1/16".
None of my daily cars that have sat outside in Idaho winters have had that condensation, and the other cars never see less than 44 degrees in the shop resting over winter.
Re: Milky oil on one cylinder rockers [Re: Pacnorthcuda] #3231490
05/06/24 10:18 PM
05/06/24 10:18 PM
5thAve Offline
5thAve  Offline
I agree. Run it for a bit and see if it improves.
Re: Milky oil on one cylinder rockers [Re: topside] #3231491
05/06/24 10:22 PM
05/06/24 10:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
That is A LOT of condensation. I have had several cars sit in unheated garages through -10 or below outside temps and have never seen condensation anywhere, especially on the dipstick. One can change the oil and cross your fingers but I wouldn't place any bets on it.
not knowing your conditions you might want to google what causes condensation and see if any of those apply. IE: warm humid air to a cold surface. Think a cold beer on a humid day. Good luck and keep us posted beer
Re: Milky oil on one cylinder rockers [Re: exile5700] #3231506
05/06/24 11:28 PM
05/06/24 11:28 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
condensation , time for a long summer drive !
