67/68 Hemi fuel flow per FSM
#3230921
05/04/24 01:27 AM
05/04/24 01:27 AM
Posts: 3,104 Morgan Hill, CA
ackpht
Morgan Hill, CA
Been having a good time working on the tuning of a '66 Hemi. Details don't appear in the '66 Field Service Manual because the Hemi was a mid-year introduction, so you have to look at the '67 FSM.
I have both the '67 and '68 FSMs and for each I calculated the fuel flow area (jet area minus rod area for primaries, jet area for secondaries). and they're shown here in square inches x 1000.
The primaries aren't all that different, but for '67 the front secondaries flow more fuel than the rears, and for '68 that is reversed, as well as the total secondary fuel area being about 25% less.
Any ideas why this was done? Were there significant differences in the engines between '67 and '68?
Re: 67/68 Hemi fuel flow per FSM
[Re: Cab_Burge]
#3231024
05/04/24 03:47 PM
05/04/24 03:47 PM
Posts: 1,328 VA
dragon slayer
VA
66 and 67 are air bypass carbs and NON emissions. Unless CA only in 67 which did have different CAP carbs.
68 was emissions all 50 states and hence the difference, beside no longer air bypass. 68 transition year and they were changing jetting, rods and the idle jet/bleeds. I assume for distribution reasons and final emission tuning. 69 up stabilized the jets and rods, with the only change being idle jets in 70/71.
[Re: dragon slayer]
#3231085
05/05/24 12:58 AM
05/05/24 12:58 AM
ackpht
Morgan Hill, CA
Thanks for the info. I have 4139 and 4140 carbs (front/rear), which references say are Hemi spec. '67 FSM lists 4139 and 4143 for non-CAP, and 4324 and 4325 for CAP. 4140 does not appear. So whatever the differences between the 4140 and the 4143 are, I'll just have to work around them.
