Stage 6 head question #323072
05/19/09 08:20 PM
05/19/09 08:20 PM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
I have a chance to buy some virgin (bare) Stage 6 heads for the 383 Satellite footbrake bracket car and I can't find any info on this part number...anybody recgonize it? P4532134, are they Max Wedge style or not? and is this a known good or bad casting? Thanks...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Stage 6 head question [Re: RapidusMaximus] #323073
05/19/09 08:37 PM
05/19/09 08:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
raised ports, standard port window. as far as the good and bad goes, i don't know. i used to build a 470 for some friends using an early set of heads. the only issue we had was head gaskets. started using 1039's and the problems ended. personally, i like them but they do need to be checked out.
Re: Stage 6 head question [Re: lewtot184] #323074
05/19/09 08:43 PM
05/19/09 08:43 PM
Arizona
Chris'sBarracuda Offline
Arizona
There is no real good Stage 6 casting, unless it's a Chapman. I don't think that part # is a Max Wedge.
They all need a bunch of work.
But work fairly well after the work.
Problem is, you can get Victors that out flow Stage 6's for way cheaper.
I wouldn't go down that road again.
Chris...
Re: Stage 6 head question [Re: Chris'sBarracuda] #323075
05/19/09 09:14 PM
05/19/09 09:14 PM
Weatherford, Texas
Weatherford, Texas
Thanks for the info...I run an old 1998 purchased set of Stage 6's on the dragster that have been extensively worked, repaired twice and are waiting for another repair, none of which was the heads fault this set came along and the price seems too good to pass up (500 for the pair)...If I buy them they will be immediately sent off to one of our resident Moparts head experts for a complete checkout, port job and build up. Just didn't want to buy a set that was a known suspicious lot.
1968 Plymouth GTX
Re: Stage 6 head question [Re: Chris'sBarracuda] #323076
05/19/09 09:22 PM
05/19/09 09:22 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
For that price, buy them. Even if you put $1000 into them, that is about the price of a pair of bare victors before the work that they require. Since you already have a set of 6s, you could re-use a bunch of stuff- no?
I'm Gumby dammit!
Re: Stage 6 head question [Re: Gumbydammit] #323077
05/19/09 10:12 PM
05/19/09 10:12 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Are those from Mancini?
Re: Stage 6 head question [Re: moparguy7074] #323078
05/19/09 10:25 PM
05/19/09 10:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Watch what you Get From Mancini. At the Chrysler Classics last weekend they had Stage 6 heads for $700 a pair, I looked them over real good, and asked what it would take to buy these BARE pair of heads....he told me $650 for Both heads...The more I thought about this, I figured something wasn't right...I went back, and after a long conversation, they guy admitted that the heads were 2nds. They were about 4-5 sets total 12:00 on Friday...Evening of Saturday there was only one bare head left.
I wondered how many of those heads had major unforeseen problems?
I also wonder How many of the buyer's knew they were 2nds...
Re: Stage 6 head question [Re: moparguy7074] #323079
05/19/09 10:32 PM
05/19/09 10:32 PM
Weatherford, Texas
Weatherford, Texas
Dont't know...it's an individual that I know and I don't know where he got them. Maybe I 'll ask... he's decided to go with 440-1s
1968 Plymouth GTX
Re: Stage 6 head question [Re: RapidusMaximus] #323080
05/20/09 09:30 AM
05/20/09 09:30 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
P4532134... is that a part # or a casting #? I don't have the old(er) Stage VI part # list in front of me (might be in the archived Tech thread on here somewhere) to cross-check it.
EDIT: Found the Tech Archive thread... I think you're looking at the casting #, not a part #:
"part #s for Stage VIs. I found '96, '99 and '02 MP catalogs and
have listed what they offered each of those years. You'll notice they've changed the
offerings a bit and there are numerous part number revisions.
1996
Standard, bare-------------------------------4529335
Standard, unmachined guides and seats--------5249051
Ported, assembled, 2.14"---------------------5249113
Ported, assembled, 2.18"---------------------5249523
1999
Max Wedge port, small chamber, bare----------5249579
"Street" Stage VI, non-raised intake port, bare------4876311
Standard, assembled (500/545 crate engine head)-----4876991
Ported, assembled, 2.14"---------------------4876186
CNC-ported, assembled, 2.18", flat-tappet springs----4876382
CNC-ported, assembled, 2.18", roller cam springs-----4876383
2002
Standard w/ CNC-machined chamber, unported, bare----4876819
Max Wedge port, standard chamber, bare-------4876818
"Aluminum 383/440" head, non-raised intake port, bare--4876311
Standard, assembled (500/575 crate engine head)----4876991
Ported, assembled, 2.18"---------------------4876187
CNC-ported, assembled, 2.18", flat-tappet springs------4876382
CNC-ported, assembled, 2.18", roller cam springs-------4876383"
Also, given all the QC issues the various sets of Stage VIs I've owned or had my hands on have had, I'd say they're ALL "seconds" they way the come from MP...
Re: Stage 6 head question [Re: BradH] #323081
05/20/09 09:54 AM
05/20/09 09:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
, I've only had a couple sets and my latest even though ported and ready to run has one head with incorrectly located DOWEL PIN holes ??? The head bolt holes are correctly placed , how the dowel pins can be off is beyond me
Re: Stage 6 head question [Re: RapidusMaximus] #323082
05/20/09 10:03 AM
05/20/09 10:03 AM
Rudolph, Ohio
Rudolph, Ohio
Only reason I asked is that Mancini was selling Stage 6 heads last weekend at the CC and they had one single bare head they were trying to sell.
Re: Stage 6 head question [Re: moparguy7074] #323083
05/20/09 10:15 AM
05/20/09 10:15 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Hey Rob,
John Yates has some Mopar heads for sale. I think they are pretty much Edelbrock RPM heads that he ran on his car for a couple of years. I think he is selling them complete with an intake, pushrods, etc. for around $1400.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Stage 6 head question [Re: lewtot184] #323084
05/20/09 11:25 AM
05/20/09 11:25 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Correct. Same casting number is sold today as P4529335 but the foundry has changed a few times.
Re: Stage 6 head question [Re: Jacob Pitt] #323085
05/20/09 09:33 PM
05/20/09 09:33 PM
Weatherford, Texas
Weatherford, Texas
Hey Rob,
Thanks, you going to Denton Saturday? I'm supposed to check the heads out there at the race.
1968 Plymouth GTX
Re: Stage 6 head question [Re: RapidusMaximus] #323086
05/21/09 06:56 AM
05/21/09 06:56 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Yeah I'll be there Saturday. My Dart is giving me issues so I don't have an electronics car for the 10grander on Sunday.
14x Track Champ
