Replacing rhe bronze gear on distributor shaft?
#3230589
05/02/24 08:12 AM
05/02/24 08:12 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you read the thread "why don't parts fit? I now am the proud owner of a new oil pump/distributor driveshaft that has a bent hex end. I could get the gear off i suppose, and swap it onto the old one with the worn gear, but i have never done it nor do i have a replacement pin for reassembly . I need to know how to do this correctly, as a mistake can cause serious damage. Thanks.
Re: Replacing rhe bronze gear on distributor shaft?
[Re: gregsdart]
#3230600
05/02/24 08:47 AM
05/02/24 08:47 AM
Posts: 2,658 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I've never done it, but it's not supposed to be hard. There should be no need for a replacement pin. The Mopar drive uses a 1-1/4" long #3 tapered pin, the Milodon uses a 3/16" x 1" roll pin.
2011 Drag Pak Challenger
[Re: rickseeman]
#3230603
05/02/24 09:04 AM
05/02/24 09:04 AM
rickseeman
Stuttgart, Arkansas
A tapered pin is, of course, bigger on one end than the other. Take your dial calipers and find out which is the big end. Use a punch and tap it out in the right direction. A normal punch is what nearly everyone would use to drive out a roll pin. Below is a picture of a 3/16" roll pin punch. A roll pin punch has a little tit on the end to keep it in place for you when you are getting started. And it is a few thou undersize to help when you are going through to hole. (A normal punch is also slightly undersize, possibly for the same reason.) Don't give up, you can do it. People sell gears, so I know people change them.
[Re: Uberpube]
#3230623
05/02/24 11:25 AM
05/02/24 11:25 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have done it and yes, it’s tough. First, grind the ends off the existing pin flush with the gear. NOTE that the pin Is NOT tapered - as evidenced by the holes in the gear being the same size all the way through. You can try pounding out the pin but I doubt it will move at all so drilling it out is the way to go. Line it up as best you can in a drill press and start with a small bit working up to close to the final size. Once the pin is out you have to press the gear off. Next, you have to line the gear up DEAD NUTS to the pin holes and press it on. Finally, when everything is back together I think you’ll find that a piece of off-the-shelf steel rod fits the pin hole nicely. Cut it a little oversized then pound the ends over like the original was. There, done !!!
Personally I’d chuck ALL your bronze gears in the trash an run a melonized gear. Never worry about bronze flakes in your motor again.
Food for thought … if the pin was tapered, why do they peen over both ends ??
[Re: Stanton]
#3230626
05/02/24 11:44 AM
05/02/24 11:44 AM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Can you buy a melonized gear with a shaft and save yourself the headache of switching them?
[Re: Stanton]
#3230817
05/03/24 01:09 PM
05/03/24 01:09 PM
Posts: 1,710 central il.
second 70
central il.
Hughe’s lists them but was always out of stock when I needed it. But well worth the extra few bucks if they have them! The gears they were using were from crane so I don't know if they're available since they went out of business.
