Re: 46RH/A518 converter
[Re: mrob]
#3230524
05/01/24 06:05 PM
05/01/24 06:05 PM
Posts: 415 Indiana
Pentastar440
Indiana
A 727 Converter will work on any 2-wire (Non Lockup) A-518 transmission
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: A727Tflite]
#3230552
05/01/24 09:06 PM
05/01/24 09:06 PM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Actually it will work on on any RE/RH if you make it a non-lockup. How does one do that? I mean the obvious part is the input shaft, and most likely part of the valve body...but any other internals???
[Re: Diplomat360]
#3230554
05/01/24 09:21 PM
05/01/24 09:21 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Actually it will work on on any RE/RH if you make it a non-lockup. How does one do that? I mean the obvious part is the input shaft, and most likely part of the valve body...but any other internals??? Input shaft , corresponding stator support I assume , make sure the interface between the input shaft , thrust washer and mainshaft works. Possibly the valvebody but since lockup is electrically applied making sure it can't happen might be enough since if you are doing it to an RE you need the electronic govenor there and working ... unless you go full manual shifting ?
[Re: Diplomat360]
#3230570
05/01/24 11:50 PM
05/01/24 11:50 PM
Posts: 3,092 Michigan
A727Tflite
Actually it will work on on any RE/RH if you make it a non-lockup. How does one do that? I mean the obvious part is the input shaft, and most likely part of the valve body...but any other internals??? Input shaft and stator support. That’s all you “have to” replace.
