Re: are BB #516 good for performance?
[Re: migsBIG]
#3229957
04/29/24 12:29 PM
04/29/24 12:29 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The closed chamber is the big selling point , especially since they can be had cheaper than 915's. they need the exh valve upgraded to at least 1.74 and porting to come alive .
[Re: migsBIG]
#3229981
04/29/24 02:03 PM
04/29/24 02:03 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: AndyF]
#3230008
04/29/24 03:28 PM
04/29/24 03:28 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I went 10.40’s with them back in the late 1970’s with a set in my 69 dart. I wouldn’t scrap them.
[Re: migsBIG]
#3230129
04/30/24 07:59 AM
04/30/24 07:59 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
Some guys on a budget want them. Some regions of the U.S. are pretty lean on old cast iron cylinder head cores. I ran a set on my 69 RR, added the 1.74 exh valve, bowl ported them with the MP templates, gained 2-3 mph through the traps. It ran low 13's @ 105 mph. Just a warmish 383 B-motor, 833, 284/484, TM6, 750 AFB, 4.30:1, 10" slicks, 1.99 60'.
[Re: migsBIG]
#3230142
04/30/24 09:01 AM
04/30/24 09:01 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
If you're on a budget, they're great in my opinion. Big exhaust valve, a little porting, and they will run decent numbers. Not aluminum head numbers, but not aluminum head $$$$ either.
[Re: Brad_Haak]
#3230150
04/30/24 09:49 AM
04/30/24 09:49 AM
Brad_Haak
Loudoun County, VA
For me to consider them, there would be two key questions to answer first: 1. What do I have to spend to make them usable in the first place (e.g., valves, seat & guide work, milling)? 2. If I want more than as-cast performance, how much do I have to pay to have someone do enough porting to reach my goals (assuming I can't do it myself)? I wouldn't want to put much money into 60 year-old castings in this day and age...
[Re: Brad_Haak]
#3230163
04/30/24 10:15 AM
04/30/24 10:15 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I look at it as……. How much less than a set of aluminum heads would the “all in” price for any old iron heads have to be for you to go down that path? And……. Can that be realistically done(price wise) in your area?
Machine shop labor prices keep going up……… but so have new aluminum heads.
[Re: pittsburghracer]
#3230445
05/01/24 11:27 AM
05/01/24 11:27 AM
Posts: 31,051 Oregon
AndyF
Yeah, 50 years ago they weren't a bad choice
[Re: AndyF]
#3230450
05/01/24 11:44 AM
05/01/24 11:44 AM
Brad_Haak
Loudoun County, VA
Yeah, 50 years ago they weren't a bad choice My days of sitting in a cold garage learning to port on a set of OEM iron heads are decades behind me
[Re: cudaman1969]
#3230688
05/02/24 06:00 PM
05/02/24 06:00 PM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
My expected combo (65 426 wedge) is the 516, 452 or Eddy head with 1.60 ex valve. Cam is limited to .431 lift and any duration no porting but any valve job. I’m thinking of running 40 degree or less seats (more flow in overlap with the low lift). What about nail head vs tulip valve shape? I have a few extra 516 heads to experiment on but still looking for the 67 small valve heads. 30deg, & a nailhead valve, works great on a low lift setup
[Re: AndyF]
#3230710
05/02/24 08:31 PM
05/02/24 08:31 PM
Posts: 13,201 aZLiViN
J_BODY
aZLiViN
Yeah, 50 years ago they weren't a bad choice Ahhhhh one of many “boneyard performance” upgrades of our youth. Grabbing a set of those was akin to crawling under a van or truck and scoring some 3.9 or 4.1 gears.
[Re: J_BODY]
#3230722
05/02/24 09:05 PM
05/02/24 09:05 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yeah, 50 years ago they weren't a bad choice Ahhhhh one of many “boneyard performance” upgrades of our youth. Grabbing a set of those was akin to crawling under a van or truck and scoring some 3.9 or 4.1 gears. Some of these guys don’t understand the fun we had making this stuff go fast. Lol
[Re: CSK]
#3230741
05/02/24 10:49 PM
05/02/24 10:49 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
My expected combo (65 426 wedge) is the 516, 452 or Eddy head with 1.60 ex valve. Cam is limited to .431 lift and any duration no porting but any valve job. I’m thinking of running 40 degree or less seats (more flow in overlap with the low lift). What about nail head vs tulip valve shape? I have a few extra 516 heads to experiment on but still looking for the 67 small valve heads. 30deg, & a nailhead valve, works great on a low lift setup Thanks
