Re: New mini starter, Bendix wouldn’t release!
[Re: Pacnorthcuda]
#3229958
04/29/24 12:31 PM
04/29/24 12:31 PM
Posts: 20,825 A collage of whims
topside
A collage of whims
Interesting...initial train of thought is that either the drive isn't retracting the pinion, or there's a bind resulting in the same thing. Second thought is whether the drive is getting a signal to retract, or not. But why would that suddenly degrade ? I can't recall anyone greasing flywheel teeth, but maybe looking at them some witness marks might be visible that indicate a bind/misalignment. That said, I can't recall any of my Mopar starters, numbering into the 20s at least, plus dozens of friends' cars, having a binding issue; they seem more locked into position than SBC starters, for example. Best test for pinion retraction would be in a bench vise - not the fun option, sounds like - but that may be necessary.
[Re: topside]
#3229962
04/29/24 12:46 PM
04/29/24 12:46 PM
Posts: 21,832 Kirkland, Washington
Pacnorthcuda
I did bench test the starter before install and it acted fine. Drove the car a little prior to this problem and it was fine, but never fully hot. This was probably the 8th-10th start since install, and the hottest (after a long slow crawl into car show).
[Re: Pacnorthcuda]
#3230087
04/29/24 10:38 PM
04/29/24 10:38 PM
Posts: 15,430 Omaha Ne
TJP
Omaha Ne
if the starter keeps cranking I'd suspect an electrical issue. one can disconnect the relay lead that energizes the solenoid. then just touch the batt cable to the post and see if it starts cranking. If it does you either have a shorted solenoid wire to the battery cable or the solenoid itself is stuck in the energized position. the above should be visible dropping the inspection cover to see if the teeth are enagged with the flywheel. Could be and interference issue but it's not something I've ever seen on a Chrysler product. maybe Ho Chi min strike again?
