98 Dakota automatic transmission overdrive wiring bypass? #3229814
04/28/24 07:44 PM
04/28/24 07:44 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, a friend of mine has a 98 Dakota with an automatic. The overdrive is not working and he wants to bypass The ECU on it and just use a toggle switch like I did on my '93. I have heard that the wiring is different on trucks newer than 93 so I can't tell him how it works. Does anybody have a wiring diagram or instructions on how to do it with the '98 models? Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Hemi_Joel] #3229827
04/28/24 08:21 PM
04/28/24 08:21 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Not sure if that can be done on an OD newer than 95? All of the newer ones are controlled by the TCM in the computers. What engine is in his Dakota? If it's a 4.7, it is an entirely different transmission than a 518 or 46RH in the older trucks. I'm not sure when they stopped the 5.2 & 5.9 Magnums in Dakotas and Durangos, but those would have had a 42RE or a 46RE in them. The 4.7 vehicles had a 545RFE. Maybe some of the guys on here who know and work on transmissions will chime in. up
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: JDMopar] #3229830
04/28/24 08:46 PM
04/28/24 08:46 PM
Minnesota
Minnesota
I assumed it was a 318, but I'll have to ask him.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Hemi_Joel] #3229859
04/28/24 11:07 PM
04/28/24 11:07 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
No 4.7 in 98.
I have a schematic, but I have to leave in a few, but I can get tomorrow am.
hth
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: A990] #3229869
04/29/24 01:40 AM
04/29/24 01:40 AM
Minnesota
Minnesota
Awesome, thanks!
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Hemi_Joel] #3229903
04/29/24 08:56 AM
04/29/24 08:56 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Here.
I hope you can bypass the PCM because the OD circuit also locks the convertor. You may have to tape over the CEL
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: JDMopar] #3229913
04/29/24 10:08 AM
04/29/24 10:08 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
OD is still controlled by a solenoid so controlling it with a toggle switch shouldn't be an issue. Same with lockup, the diesel guys have been controlling the Lockup with a switch on the RE's forever ... All he has to do is switch ground .
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: JohnRR] #3229922
04/29/24 10:44 AM
04/29/24 10:44 AM
BDW Offline
BDW  Offline
I always read the RE has a digital code needed, not just grounding the pins like the RH?
Would have gotten a RE if that were the case instead of the 518 when I did the swap.
I know there are controllers for the RE available.
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: BDW] #3229952
04/29/24 12:18 PM
04/29/24 12:18 PM
JohnRR Offline
JohnRR  Offline
I'm looking at the pages provided above and it doesn't look that way for OD and lockup anyway ?? The RE needs digital for the gov pressure circuit , on my 2000 ram I put a resistor on the line to the PCM (BCM?) to fool the gov pressure circuit to not see the increased pressures , that worked perfect for over 200K miles ...
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: JohnRR] #3230274
04/30/24 04:19 PM
04/30/24 04:19 PM
hooziewhatsit Offline
Correct. On the RE, the computer controls the governor pressure (trying to get ~1psi/mph, then the valves in the transmission control shift points off of that).
Lockup & OD are still solenoids that can be triggered externally. Computer may not like it though argue
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: hooziewhatsit] #3230278
04/30/24 04:37 PM
04/30/24 04:37 PM
Minnesota
Minnesota
Thanks for the help.
With this being a '98, would it have the RE, with the computer control of more than just the lock-up and OD?
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Hemi_Joel] #3230287
04/30/24 04:54 PM
04/30/24 04:54 PM
A727Tflite Offline
A727Tflite  Offline
Round black connector in the case = RE.
White oval connector in the case = RH. (The hole in the case is round but the connector top is oval).
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: A727Tflite] #3230303
04/30/24 05:47 PM
04/30/24 05:47 PM
BDW Offline
BDW  Offline
Isn't easier than that?
RE = 5 pins
RH = 3 pins
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: A727Tflite] #3230304
04/30/24 05:48 PM
04/30/24 05:48 PM
Nevada
merpar Offline
merpar  Offline
Nevada
The RE has a 3 prong connecter the RH has a 2 prong connecter
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: merpar] #3230306
04/30/24 06:05 PM
04/30/24 06:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
RE has LOTS of wires, RH has 3 ,, center one is + one outer is lock up, the other outer is OD
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: CSK] #3230356
04/30/24 09:45 PM
04/30/24 09:45 PM
A727Tflite Offline
A727Tflite  Offline
RE has 8 PINS.
RH has either 2 or 3 PINS. 2 for non LU and 3 with LU.
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Hemi_Joel] #3230424
05/01/24 09:25 AM
05/01/24 09:25 AM
JohnRR Offline
JohnRR  Offline
98 should be RE , they started either 95 or 96 ...
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: JohnRR] #3231049
05/04/24 05:10 PM
05/04/24 05:10 PM
Minnesota
Minnesota
He brought the truck over today and I went under and looked at it. He said the engine is a 318, but the original transmission was bad and one was swapped in out of a 93 he thinks. Also the wires are bare, as you can see in the picture, and they were touching. So I separated them out.
So one of these gets grounded to activate the overdrive, right? The brown green one? Or does it get 12 volt positive supplied to it? And then apparently the black one activates the lockup converter. If it's really a 93 transmission, does it even have lockup capability?
Thanks a lot, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Hemi_Joel] #3231055
05/04/24 06:11 PM
05/04/24 06:11 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
You know, the part number stamped on the case would tell you exactly what it was then you wouldn't have to guess.
Re: 98 Dakota automatic transmission overdrive wiring bypass? [Re: Sniper] #3231123
05/05/24 11:18 AM
05/05/24 11:18 AM
moparx Offline
moparx  Offline
i was under the assumption those transmissions used the new style plastic pan gasket with the imprinted seal stuff on it, so as to be reusable ?
beer
