Re: Does anyone make a fuel sender that works??
[Re: TJP]
#3229118
04/25/24 12:26 PM
04/25/24 12:26 PM
Posts: 5,970 ohio
ruderunner
ohio
[quote=ruderunner]Theory on why senders read full during a dry test vs actual use.
We're adjusting the senders and assuming the float will reach the top of the tank.
We're forgetting about air space above the fuel and the fact that the float won't touch the top of the tank in operation.
If someone is in this process, try setting the float for an inch gap from the top of the tank. Why do you believe there is air space at the top of the tank? IF the filler neck on say a 68-70 Charger is full of fuel, how could there be an air space ? Whether the neck is full or not, there's still going to be air pockets in the tank. Even the vent lines aren't completely against the top of the tank. Either way, the test is simple enough to try.
Angry white pureblood male
[Re: moparx]
#3229120
04/25/24 12:51 PM
04/25/24 12:51 PM
Posts: 15,960 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
"Why do you believe there is air space at the top of the tank? IF the filler neck on say a 68-70 Charger is full of fuel, how could there be an air space ?" i have screwed up filling up my charger till the fuel ran all over the quarter, and out the vent line [which dumps into the frame rail] making a real mess. i don't think there was any air that time. [sure stayed on full for long time.] however, that was tons of years ago, and i'm super careful these days filling it up. also, the mess was during the time i had the original tank and sender in it. I've had nothing but problems filling older cars with gas and the spill over. I don't know if it's in the design of newer pump nozzles or what, but now I put my ear down and listen for it getting full and stop manually.
Facts are stubborn things.
[Re: TJP]
#3232604
05/13/24 05:48 PM
05/13/24 05:48 PM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
After weeks of messing with this I ended up buying a new Auto Meter fuel gauge and Auto Meter fuel bridge to try out (pic). Couldn't get the fuel bridge to work as it should so I hooked the gauge up directly to my sender. The gauge now reads the sender but it reads backwards, full when empty and empty when full. At least now I know when it's empty or full just have to remember it's backwards. I can live with that.
[Re: TJP]
#3233393
05/17/24 05:35 PM
05/17/24 05:35 PM
GODSCOUNTRY340
After weeks of messing with this I ended up buying a new Auto Meter fuel gauge and Auto Meter fuel bridge to try out (pic). Couldn't get the fuel bridge to work as it should so I hooked the gauge up directly to my sender. The gauge now reads the sender but it reads backwards, full when empty and empty when full. At least now I know when it's empty or full just have to remember it's backwards. I can live with that. Not sure how that's wired but typically a DC circuit will indicate backwards if the polarity is reversed. So you might want to double check the wiring Yeah, that's what I was thinking, already tried that, same problem. The Auto Meter instructions say if the gauge reads backwards switching wires won't fix, need to buy a sender that's compatible with their gauge. I'm on my 3rd sender, I'll just live with what I have now. Tired of dropping the tank for this. Plus no one can seem to build a sender compatible for Mopar gauges, how in the world do we find a sender that will fit in an A body Mopar and be compatible with Auto Meter gauge? Good luck finding one of those, probably not even made.
[Re: GODSCOUNTRY340]
#3233440
05/17/24 10:43 PM
05/17/24 10:43 PM
Posts: 15,567 Omaha Ne
TJP
Omaha Ne
I went through quite a circle jerk with them several years back on a VERY expensive set of programmable digital gauges in a customers car. they said they no longer have engineering as it is all done outside. I did what one is not supposed to and changed 3 things at the same time. I don't know to this day what fixed the issue we were having as it magically just started working. After losing 60+ hours on the problem I wasn't going to backtrack and try to identify the root cause. Still have a bunch of components that they kept sending ( throw parts at it) They are not the company they once were I just did a quick scan on the instructions and it should work I'll repeat, They are not the company they once were
[Re: TJP]
#3233489
05/18/24 09:52 AM
05/18/24 09:52 AM
GODSCOUNTRY340
okay, there are 3 prongs on the gauge; sender, ignition and ground, what wires do I switch? The instruction clearly state; swapping wires will not solve the problem.
#3233567
05/18/24 03:44 PM
05/18/24 03:44 PM
Posts: 4,769 Moved to N.E. Tennessee
GomangoCuda
Does anyone make a fuel sender that works?? Short answer is NO. There used to be someone that rebuilt OEM senders. I don't know if he is still around.
#3233625
05/18/24 11:11 PM
05/18/24 11:11 PM
TJP
Omaha Ne
okay, there are 3 prongs on the gauge; sender, ignition and ground, what wires do I switch? The instruction clearly state; swapping wires will not solve the problem. Saw that, but they also claim it will work with any sender or you can do a custom calibration As I mentioned they are not the company they once were. out of curiosity did you try # 6 on the list ? One could try swapping the 12V source and gauge ground but if they say that won't work ask the [censored] will ???
[Re: TJP]
#3233676
05/19/24 11:00 AM
05/19/24 11:00 AM
GODSCOUNTRY340
Yeah, I tried every one of those, couldn't get any of them to work, so I hooked the gauge direct to the sender and it reads the full range but backwards. Might just install the gauge upside down, at least it will read as empty on the left and full on the right side like a factory gauge. Thanks for all the input. What makes me mad is Chrysler made a sender that works, why can't aftermarket reverse engineer Mopar's sender and make one that reads correct? Guess the engineers back in the day were a lot smarted than this new crop of engineers.
#3233731
05/19/24 03:19 PM
05/19/24 03:19 PM
TJP
Omaha Ne
Yeah, I tried every one of those, couldn't get any of them to work, so I hooked the gauge direct to the sender and it reads the full range but backwards. Might just install the gauge upside down, at least it will read as empty on the left and full on the right side like a factory gauge. Thanks for all the input. What makes me mad is Chrysler made a sender that works, why can't aftermarket reverse engineer Mopar's sender and make one that reads correct? Guess the engineers back in the day were a lot smarted than this new crop of engineers. per there diagram and instructions there is no reason it shouldn't work correctly. They even show the sending unit as working off resistance to ground. Providing your sending unit is properly grounded (worth a check) which you've likely already done. One could try Running a separate jumper from the battery negative to both the gauge and sending unit. doesn't have to be more than 16 ga, (18 would probably work). If that doesn't work try a jumper from the Positive post to the gauge. There is also mention of a "Custom calibration routine" when the S/U resistance is unknown. not sure if you tried that or not. Still reads backwards? You have a bad gauge or bridge PERIOD!!!!. This is not rocket science. They are BS'lng you if so inclined one can even use 0-100 ohm rheostat in place of the sending unit. bet it still reads backwards. P's me off what our support systems have evolved into (worn out jock straps). I'm going to assume that at least your not talking to a foreign country YET!!!
[Re: moparx]
#3233735
05/19/24 03:33 PM
05/19/24 03:33 PM
Posts: 5,970 ohio
ruderunner
ohio
back in my working career as a machinist/shift supervisor, i can't count how many times i argued with company engineers on all kinds of topics, including sequence of machining operations, tolerances, measuring techniques, etc. in case you don't know, engineers are the smartest people on earth. just ask 'em........... As the son of an engineer, can confirm. 15 years after his death, I'm still cleaning up his mistakes.
[Re: TJP]
#3233737
05/19/24 03:35 PM
05/19/24 03:35 PM
Posts: 5,970 ohio
ruderunner
ohio
Yeah, I tried every one of those, couldn't get any of them to work, so I hooked the gauge direct to the sender and it reads the full range but backwards. Might just install the gauge upside down, at least it will read as empty on the left and full on the right side like a factory gauge. Thanks for all the input. What makes me mad is Chrysler made a sender that works, why can't aftermarket reverse engineer Mopar's sender and make one that reads correct? Guess the engineers back in the day were a lot smarted than this new crop of engineers. per there diagram and instructions there is no reason it shouldn't work correctly. They even show the sending unit as working off resistance to ground. Providing your sending unit is properly grounded (worth a check) which you've likely already done. One could try Running a separate jumper from the battery negative to both the gauge and sending unit. doesn't have to be more than 16 ga, (18 would probably work). If that doesn't work try a jumper from the Positive post to the gauge. There is also mention of a "Custom calibration routine" when the S/U resistance is unknown. not sure if you tried that or not. Still reads backwards? You have a bad gauge or bridge PERIOD!!!!. This is not rocket science. They are BS'lng you if so inclined one can even use 0-100 ohm rheostat in place of the sending unit. bet it still reads backwards. P's me off what our support systems have evolved into (worn out jock straps). I'm going to assume that at least your not talking to a foreign country YET!!! ______ You're onto something here's. How good IS the ground? And folks laughed at me because I mentioned that the float may not actually touch the top of the tank when the tank is full.
[Re: ruderunner]
#3233840
05/19/24 10:43 PM
05/19/24 10:43 PM
TJP
Omaha Ne
Yeah, I tried every one of those, couldn't get any of them to work, so I hooked the gauge direct to the sender and it reads the full range but backwards. Might just install the gauge upside down, at least it will read as empty on the left and full on the right side like a factory gauge. Thanks for all the input. What makes me mad is Chrysler made a sender that works, why can't aftermarket reverse engineer Mopar's sender and make one that reads correct? Guess the engineers back in the day were a lot smarted than this new crop of engineers. per there diagram and instructions there is no reason it shouldn't work correctly. They even show the sending unit as working off resistance to ground. Providing your sending unit is properly grounded (worth a check) which you've likely already done. One could try Running a separate jumper from the battery negative to both the gauge and sending unit. doesn't have to be more than 16 ga, (18 would probably work). If that doesn't work try a jumper from the Positive post to the gauge.There is also mention of a "Custom calibration routine" when the S/U resistance is unknown. not sure if you tried that or not. Still reads backwards? [b ]SEE BELOW[/b] You have a bad gauge or bridge PERIOD!!!!. This is not rocket science. They are BS'lng you if so inclined one can even use 0-100 ohm rheostat in place of the sending unit. bet it still reads backwards. P's me off what our support systems have evolved into (worn out jock straps). I'm going to assume that at least your not talking to a foreign country YET!!! ______ You're onto something here's. How good IS the ground? And folks laughed at me because I mentioned that the float may not actually touch the top of the tank when the tank is full. Another question just occurred to me, referring to their chart pictured in a previous post does their first number refer to a full or empty tank. I would ASSume empty BUT? Form tanks website: The resistance of your fuel sender should match that of your gauge. For instance the resistance of the stock gauge in a 55 Chevy has a value of zero ohms when empty and 30 ohms when full. The following list is for stock gauges and some popular aftermarket brands: Ford up to 1986 - 73-10 Ohms Ford 1987 & up - 16-158 Ohms GM up to 1964 - 0-30 Ohms GM 1965-1997 - 0-90 Ohms GM 1998 & up - 40-250 Ohms Mopar up to 1986 - 73-10 OhmsAMC 1950-1977 - 73-10 Ohms Autometer -240-33 Ohms is the most common however other ohm ranges are made Classic Instruments - 240-33 Ohms (excluding vehicle specific gauge kits which use factory ohm range) Dolphin - 0-90 Ohms Dakota Digital - Programmable to work with most Ohm range senders VDO - 10-180 Ohms The first number represents the empty Ohm reading and the second number is the full reading.IF their chart is reverse of the above, that would cause the problem. IF your sending units resistance board was installed upside down, THAT would also cause the problem. Easily verified by checking the readings at full and near empty. You can also verify the grounds a suggested earlier. last on their list is a 0-1000 ohm custom calibration that should correct the issue regardless, providing the GROUNDS are good. Keep us posted
