1967 Barracuda Bumper Bracket Bolt? #3225872
04/08/24 06:46 PM
04/08/24 06:46 PM
Cleveland, Oh.
71rt4spd Offline OP
71rt4spd  Offline OP
Cleveland, Oh.
Could anyone advise the correct bolt size that bolts the rear bumper bracket on 67 Barracuda to the body? its either 7/16" or 1/2" just not sure-
Thanks in advance-
-Dave
Re: 1967 Barracuda Bumper Bracket Bolt? [Re: 71rt4spd] #3226789
04/12/24 10:02 PM
04/12/24 10:02 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
drive Hi Dave , The bolts for Rear Barracuda Bumper Support Bracket , Parts Manual Section 13-66-16 , measure 7/16 X 14 NC , and are 1.50" long Grade 5 . wave Ronnie
Re: 1967 Barracuda Bumper Bracket Bolt? [Re: 1969ronnie] #3228877
04/24/24 06:26 AM
04/24/24 06:26 AM
Cleveland, Oh.
71rt4spd Offline OP
71rt4spd  Offline OP
Cleveland, Oh.
Thanks Ronnie, appreciate it -
-Dave
Re: 1967 Barracuda Bumper Bracket Bolt? [Re: 71rt4spd] #3228912
04/24/24 11:13 AM
04/24/24 11:13 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I have a set of you need some pictures.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1967 Barracuda Bumper Bracket Bolt? [Re: BloFish] #3228932
04/24/24 12:37 PM
04/24/24 12:37 PM
1969ronnie Offline
1969ronnie  Offline
drive Hi Dave , Don't forget to add the 4 retaining washers , Part # 6026 647 , Parts Catalog Section 13-66-15 between the rear bumper bracket and the body . That Retainer is also used on the 7/16" rear axle studs to hold the brake drum before Rim was installed . drive Nobody installs the retaining washers after dismantling and restoring the rear bumper brackets . wave
