1971-78 Dodge Plymouth Chrysler Cruise Control Lever 3746518
[Re: Memongo]
#3224648
04/03/24 07:38 AM
04/03/24 07:38 AM
Posts: 4,161 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
1971-78 Dodge Plymouth Chrysler Cruise Control Lever 3746518. Used, $50 + Shipping, Payment via US Postal Money Order Only! Shipping: US Address Only! Call Steve 810-629-1097
Re: A Body - Parts For Sale 2nd Quarter
[Re: moparts]
#3225323
04/05/24 11:37 PM
04/05/24 11:37 PM
Posts: 1,544 CT
mrrandyj
CT
Rear trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price. Made in the USA. Email mrrandyj@aol.com
]1968 Dart GTS Door Panel Emblem
[Re: moparply]
#3228795
04/23/24 03:56 PM
04/23/24 03:56 PM
Posts: 476 NJ
Nvr4Get911
NJ
1968 Dart GTS Door Panel Emblem Used, all 3 mounting prongs are intact. ...$100. Shipped in USA Payment is USPS money order or Cash on pickup. PM me worldwide. Email me pursuitison@live.com
Misc. A body parts
[Re: Nvr4Get911]
#3229102
04/25/24 11:09 AM
04/25/24 11:09 AM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Mr. Norms - Dream Motors Super Charger vintage sticker - $40 - Will sell unframed for $25
NEW - Pack of (3) different Master cylinder gaskets ; 2) foam 1) gasket material - $6
NEW- Power steering return hose/clamps - $10
NEW - A BODY Fresh air vent to cowl seal (DMT) 63-66 fresh air vent to cowl, 67-76 NON A/C heater box to cowl, 67-72 AC heater box to cowl $8
NEW - Horn buzzer relay (aftermarket) - $15
NEW - Header bolts hex head (9) - $10
NEW - 69-74 brake distribution block part #BLK250 - $60
NEW - (rebuilt) by Brake/Equipment Warehouse in MN - Weatherhead brake distribution valve - $200
NEW - 72-76 A body Rear axle brake line brass T (no bolt) - $15
NEW - 1970-71 340-440 Carter AVS Idle solenoid bracket - $30
NEW - LARGE chrome master cylinder cover with bail wire - says "WARNING - clean filler cap before removing, use only DOT3 fluid from a sealed container" - $25
USED - misc. seat belt mounting bolts x 12 - $20
USED - freshly refurbished A body blower motor mounting bracket to firewall with new gasket - $30
****PM IF YOU NEED TO SEE CLOSE UP OF A PARTICULAR PART - THANKS****
GY3 71 Demon 340
1966 Plymouth Barracuda Center Grille Emblem
[Re: moparply]
#3229326
04/26/24 02:06 PM
04/26/24 02:06 PM
Posts: 476 NJ
Nvr4Get911
NJ
...Used OEM Part# 2582427, has some pits / blemishes.
Overall it will display NICELY on your Cuda!!!
1 prong is broken off but it will secure to your grill just fine or try repairing it to your liking......Fish is tightly in place!!!
.......$100. + shipping....Payment is USPS money order or Cash on pickup
NOS 1971 Plymouth Duster owners manual
[Re: Nvr4Get911]
#3229752
04/28/24 03:14 PM
04/28/24 03:14 PM
Posts: 2,264 Western,NY
JEJJ
Western,NY
NOS 1971 Plymouth Duster owners manual, NOT REPRO.......has slight yellowing,but otherwise NICE NOS, tight, unwritten in and with the perforated page to fill out and tear off to send in the Chrysler Motors Corporation...........$40
Thank you
716-997-007
bakurruda@aol.com
