2500 CTD Suggestions
#3228450
04/21/24 06:29 PM
04/21/24 06:29 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
I have a 2007 2500 CTD 4x4. Bought it new in 2007. The issue at hand is my wife has bad knees and finds it hard to get into the truck. I have running boards which helps but she still has problems. I’m looking for a way that I can lower the front of the truck so that it’s easier for her to get in. Selling or trading in the truck for a new 2WD is not an option. I’ve seen airbag suspension but not sure of the capacity of what’s available. Any suggestions would be helpful.
Abe Lincoln
Re: 2500 CTD Suggestions
[Re: dart4forte]
#3228451
04/21/24 06:37 PM
04/21/24 06:37 PM
Posts: 4,771 Star Idaho
67vertman
Star Idaho
Semi trucks weighing 80,000 pounds use air bags. So they make ones to handle a pick-up truck weight.
With air bags you may only get about four inches of drop, is that sufficient to help her get in?
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3228466
04/21/24 07:30 PM
04/21/24 07:30 PM
dart4forte
Mesa, Arizona
4 inches would be perfect
Abe Lincoln
[Re: dart4forte]
#3228510
04/21/24 10:43 PM
04/21/24 10:43 PM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
What about an electric running board ?
[Re: poorboy]
#3228565
04/22/24 10:14 AM
04/22/24 10:14 AM
dart4forte
Mesa, Arizona
Do you have a grab handle mounted inside the cab that your wife can grab and help pull herself up into the cab? If she can open the door, garb a hold of a handle that she can pull herself up onto the running board and then into the cab, that might help a lot.
My buddy's wife has MS. For years he has used a small 2 step stool he puts on the ground (stores it behind the seat on his extended cab truck) for her to step on to get into and out of his truck. The step stool and the grab handle has worked for them for several years. We have a sept stool and there’s aN OE grab handle. The step stool is a PIA, unfold and fold every time we use it. I’ve tried several stools but none are as steady as the trucks side board. It just needs to be a little lower.
Abe Lincoln
[Re: moparx]
#3228785
04/23/24 01:38 PM
04/23/24 01:38 PM
dart4forte
Mesa, Arizona
could the present running board mounting brackets be modified somewhat easy to lower the step surface ? I’m actually looking at that
Abe Lincoln
[Re: volaredon]
#3230197
04/30/24 12:05 PM
04/30/24 12:05 PM
Posts: 1,159 Cruising!
QuickDodge
Cruising!
If the OP's wife is losing her mobility and her condition is expected to worsen, it may be wise to do more than a different running board or step. There are devices the seat can mount to that move the seat out and drop it down close to the ground. These are typically used by folks in wheelchairs that can NOT stand on their own. Unfortunately, these are not cheap products. I've thought about getting one of these for my parents, but so far a stool is working for them. There are days when it is a struggle though.
[Re: QuickDodge]
#3233841
05/19/24 10:45 PM
05/19/24 10:45 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Try a set of front springs for a V10 and remove the rear block between the leafsprings and rear axle.
That should lower it about 2". The V8 2500 springs or Power Wagon springs can be used if the V10's don't do enough. Have to do your research on the spring rates before buying parts.
If you lower it any more the front will bottom out
Mo' Farts
Moderated by "tbagger".
