8 3/4 ID ??? help #3228486
04/21/24 09:15 PM
04/21/24 09:15 PM
Fairfax, Virginia
Juan-N-Million Offline OP
Fairfax, Virginia
Hello all, can anyone help me identify what this 8 3/4 came out of or from what year it’s from
? I thought maybe it was a 489 casing and it was a defect b/c it doesn’t have a “9” at the end Thank you!!
Re: 8 3/4 ID ??? help [Re: Juan-N-Million] #3228497
04/21/24 09:53 PM
04/21/24 09:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's a 489 , the last digit of the casting number is MIA ... 489 had that large 9 cast on them.
does it have the caps , those are not a one size fits all , if it doesn't have them it's going to be $$$ to put another set on.
To me without them it's scrap, I just sold a few empty 489's , with caps , for 35 bucks a pop
Re: 8 3/4 ID ??? help [Re: JohnRR] #3228500
04/21/24 10:02 PM
04/21/24 10:02 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Caps? shruggy
Re: 8 3/4 ID ??? help [Re: Ramrod39] #3228517
04/21/24 11:11 PM
04/21/24 11:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bearing caps.
Re: 8 3/4 ID ??? help [Re: stumpy] #3228520
04/21/24 11:13 PM
04/21/24 11:13 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
caps general photo
Re: 8 3/4 ID ??? help [Re: SALEM1912] #3228540
04/22/24 04:48 AM
04/22/24 04:48 AM
Fairfax, Virginia
Fairfax, Virginia
Thanks all!! Hi yes I have the caps and the internals to go with it. It had a 3.23 Non-Posi Unit in it. I took it apart to add a Sure Grip unit to it
Re: 8 3/4 ID ??? help [Re: Juan-N-Million] #3228541
04/22/24 05:59 AM
04/22/24 05:59 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Did the caps get marked before removing? They're side specific.
If not, bolt them oon and see if the adjustment threads line up. Switch sides and repeat.
Angry white pureblood male
Re: 8 3/4 ID ??? help [Re: stumpy] #3228691
04/23/24 02:00 AM
04/23/24 02:00 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Originally Posted by stumpy
Bearing caps.
OK. Now I get it. Thanks.
Re: 8 3/4 ID ??? help [Re: Ramrod39] #3228849
04/23/24 10:11 PM
04/23/24 10:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
To answer the original question, I think that may be a pre 62 8-3/4 housing but not 100% on that. I do know they used different casing numbers in the earlier years
I am not sure of any differences either way shruggy Hopefully you did mark the bearing caps so they get back on their respective sides wink
beer
Re: 8 3/4 ID ??? help [Re: TJP] #3228866
04/24/24 01:56 AM
04/24/24 01:56 AM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
I think the early ones up to 64 were 1820654 and small pinion
Re: 8 3/4 ID ??? help [Re: fullonmopar] #3228892
04/24/24 09:34 AM
04/24/24 09:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , the one pictured above is definitely a 489 , they are the only one with the large cast 9
Re: 8 3/4 ID ??? help [Re: JohnRR] #3229037
04/24/24 11:30 PM
04/24/24 11:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'm confused, where do you see a "LARGE Cast 9" ? confused
Re: 8 3/4 ID ??? help [Re: TJP] #3229047
04/25/24 01:29 AM
04/25/24 01:29 AM
How about the first picture next to the carrier adjuster cap area scope up
Re: 8 3/4 ID ??? help [Re: Cab_Burge] #3229228
04/25/24 09:54 PM
04/25/24 09:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Would've never guessed that one up beer
