6 bbl surge #3228279
04/20/24 01:50 PM
04/20/24 01:50 PM
Illinois, USA
superbee69 Offline OP
Illinois, USA
When driving say average 65mph are you getting any fuel from outer carbs or just center? I'm getting slight surge at 65 or so thought I would step up a jet size or two in center, lower speeds around town seem fine.
Re: 6 bbl surge [Re: superbee69] #3228346
04/20/24 10:52 PM
04/20/24 10:52 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
might be ignition
try it without vac adv hooked up . might need dist curve adjusted .
what size jets are in center carb ? 63 or 64 normally good .
Re: 6 bbl surge [Re: calrobb2000] #3228347
04/20/24 10:58 PM
04/20/24 10:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by calrobb2000
hi
might be ignition
up Also check your initial and total timing without the Vac, advance. S/be around 10-15 initial with a total of about 34-38. WITHOUT THE VACUUM ADVANCE wink beer
Re: 6 bbl surge [Re: TJP] #3228374
04/21/24 08:22 AM
04/21/24 08:22 AM
Illinois, USA
Illinois, USA
MSD dist will check timing thanks for the replies
Re: 6 bbl surge [Re: superbee69] #3228455
04/21/24 06:49 PM
04/21/24 06:49 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Please do not over jet...63/4's is a not recommended.
62's may even be too large if this is nothing high hp, 61 may likely be required.
The secondaries when closed are constantly providing fuel...always...so they make up the rest of the jetting total - they have adjustment screws to add or subtract fuel
When the secondaries open they provide air/more fuel and of course the OH WOW! acceleration. Let me see that happen with efi or a 4bbl....I'm waiting eek
drive
More than likely the six pak set up and the over all tune up is not Goldilocks [just right] so there are problems like surging etc etc etc
Re: 6 bbl surge [Re: superbee69] #3228473
04/21/24 07:54 PM
04/21/24 07:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Which MSD distributor, self contained or with one of their separate ignition boxes, ECU?
Re: 6 bbl surge [Re: Cab_Burge] #3228479
04/21/24 08:33 PM
04/21/24 08:33 PM
Illinois, USA
Illinois, USA
stand alone no box not a fan= [fazing]and all
Re: 6 bbl surge [Re: superbee69] #3228568
04/22/24 10:35 AM
04/22/24 10:35 AM
[spoiler][/spoiler]Sounds like it might be the distributor trying to add timing at cruise RPM scope work twocents
I try to recurve all my distributors to get all the mechanical advance in by 1600 to 2000 RPM max up shruggy
Have you tried tuning the outboard carb idle fuel ratio with the idle fuel adjuster screws in the base plates? If not try gently closing them until fully seated and then back out from 1/3 to 1/2 turn out from fully, seated depending on what altitude you're at wrench up twocents
Six packs rule when they are tuned properly tuned wrench: scopeup
Re: 6 bbl surge [Re: superbee69] #3228658
04/22/24 09:59 PM
04/22/24 09:59 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Wrong gas cap or gas tank venting issue?
Re: 6 bbl surge [Re: Cab_Burge] #3228665
04/22/24 10:58 PM
04/22/24 10:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: 6 bbl surge [Re: TJP] #3228749
04/23/24 12:05 PM
04/23/24 12:05 PM
moparx Offline
moparx  Offline
iagree
the vacuum can is adjustable with a 3/32 allen key inserted into the nipple end. have you tried adjusting that ?
you could have too much vacuum at cruise, causing an over advanced ignition curve.
beer
Re: 6 bbl surge [Re: moparx] #3228779
04/23/24 01:31 PM
04/23/24 01:31 PM
Illinois, USA
Illinois, USA
no vac advance promax metering plate ,rear base plate and jettable plates in outboard carbs .where should you get vacuum with promax center metering plate
Re: 6 bbl surge [Re: superbee69] #3228822
04/23/24 08:10 PM
04/23/24 08:10 PM
Chicago
PurpleBeeper Offline
Chicago
That’s a can of worms! Factory was metering plate. Some people like manifold vacuum. I don’t have my vacuum advance hooked up either, no problem
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 6 bbl surge [Re: superbee69] #3228844
04/23/24 09:44 PM
04/23/24 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If you're not running the vacuum advance, move on to checking the initial and total timing. Might want to verify the timing mark is correct when at TDC beer
