Anyone have a 2003 Comp Cams Catalog? #3228021
04/19/24 09:05 AM
04/19/24 09:05 AM
tboomer Offline OP
tboomer  Offline OP
I talked to the fella that rebuilt the 340 in my 69 GTS in Nov. of 2003. He only kept receipts for around ten years on the engines he has built. I have the original receipts from 2003 and thought it was cool to talk to this fella that is in his mid 70s. He remembered a lot about my car but could not tell me what cam was in it. On the receipt it says Comp Cams camshaft and lifter kit. It was a bit over 200.00 back then. It is a hydraulic and has a bit of a lopey idle to it. It looks like the valve springs were 90.00 and the rocker arms were around 120.00. Any good guesses? Thanks! Ted wave
Re: Anyone have a 2003 Comp Cams Catalog? [Re: tboomer] #3228025
04/19/24 09:22 AM
04/19/24 09:22 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Here is a 'Mopar Cams' section out of 2006 year, not sure that'll help though w/o the matching pricing and no other info (cam spec wise)?
Attached PDF document
Re: Anyone have a 2003 Comp Cams Catalog? [Re: Diplomat360] #3228205
04/20/24 05:38 AM
04/20/24 05:38 AM
tboomer Offline OP
tboomer  Offline OP
Thanks! Just looked at it and there's quite a few listed indeed! wave
Re: Anyone have a 2003 Comp Cams Catalog? [Re: tboomer] #3228573
04/22/24 11:09 AM
04/22/24 11:09 AM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
https://web.archive.org/web/2003112...echnical/Catalogs/106-03/PDF/Default.asp
Re: Anyone have a 2003 Comp Cams Catalog? [Re: Wheeler] #3228586
04/22/24 12:19 PM
04/22/24 12:19 PM
tboomer Offline OP
tboomer  Offline OP
Thanks! We can't figure it out. If it ain't broke, don't fix it!! wave
