Late B-Body Rear Sway Bar End Link Part Number? #3227962
04/18/24 08:38 PM
04/18/24 08:38 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
So...I broke one of my two rear sway bar end links pulling the rear axle on my Charger. For the life of me, I can't find a replacement, even expanding to 1971-74 cars. Can anyone point me in the right direction? Part number? Anything?
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Remy-Z] #3227966
04/18/24 09:29 PM
04/18/24 09:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Rear sway bar in a B-body? New one on me. I thought the only ones with rear sway bars were E-bodies.
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: 6PakBee] #3227971
04/18/24 09:50 PM
04/18/24 09:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
what year car?
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: mopars4ever] #3227981
04/18/24 10:20 PM
04/18/24 10:20 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Firm Feel makes a rear sway bar kit for a 76 Charger, similar mounting as to factory. They might have what you need?
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Sniper] #3228014
04/19/24 07:45 AM
04/19/24 07:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I had a 1974 charger rallye it had one as for helping the original poster I thought end links were kind of universal you just need the right length. Although that car also had the iso -leafs
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: B1MAXX] #3228017
04/19/24 08:13 AM
04/19/24 08:13 AM
md
mopars4ever Offline
mopars4ever  Offline
md
If the end links are the same as a 78 volare then no none are available that I could find. You could do what B1MAXX said. Many different universal lengths out there.
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: B1MAXX] #3228031
04/19/24 10:32 AM
04/19/24 10:32 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Nope,, they look like this
Mopar part number is 2269709. They are available NOS fro several sources
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Sniper] #3228068
04/19/24 12:07 PM
04/19/24 12:07 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yep, but you could still fab pretty easy if you had to.
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: B1MAXX] #3228089
04/19/24 01:27 PM
04/19/24 01:27 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My 77 book show two different part numbers. For standard with rear isolators and HD with out . 4106151 and 4106152 None around that I can find. Time to weld the old one if fixable And the aspen volare uses a different type of end link.
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: mopars4ever] #3228091
04/19/24 01:33 PM
04/19/24 01:33 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Your numbers are probably right, mine is just he square bushing, which the OP doesn't need, he needs the whole link assembly,
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Sniper] #3228092
04/19/24 01:35 PM
04/19/24 01:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
that is the part numbers for the link assy
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Sniper] #3228099
04/19/24 01:51 PM
04/19/24 01:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
2269709 is a bushing
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: mopars4ever] #3228133
04/19/24 06:08 PM
04/19/24 06:08 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
Here is a shot of what I broke. It's a '76 Charger, and I've known of other "performance" or towing package B-bodies packing a sway bar in the back. The FirmFeel bar is more money than I'd like to spend to fix one snapped sway bar end link...I need to be able to afford other parts they sell!
Edit: What's the likelihood that E-body and late-B body links would interchange? Seems like most everything else "black metal" does.
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Remy-Z] #3228135
04/19/24 06:17 PM
04/19/24 06:17 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have to wonder how close the 73 74 charger rear sway bar bracket is if not the same as the the later years like yours. The strap part number 3402897 listed in the pic I posted is the same as 73 up b body. https://www.hiltopautoparts.com/pro...iner-1973-4-b-body-1972-3-c-body-models/ You could weld a bolt to it if you can`t find one. The replacement kit 4106151( if you can find one) is a bolt on type not like the OE that looks welded.
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: 6PakBee] #3228334
04/20/24 08:30 PM
04/20/24 08:30 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Yep, can be ordered separately or comes in a handling package, or if you got a Magnum GT, or 79 300. About every Magnum I've owned has had one. Even 318 cars.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Magnumguy] #3228337
04/20/24 08:59 PM
04/20/24 08:59 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
My 76 charger had one but 75 cordoba and 78 fury didn't/don't
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Magnumguy] #3228380
04/21/24 09:11 AM
04/21/24 09:11 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Learned something again. up
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: Remy-Z] #3228623
04/22/24 06:11 PM
04/22/24 06:11 PM
IMGTX Offline
IMGTX  Offline
E body is no dice. They use the traditional type where the sway bar is mounted to the frame and the ends connect with the link.
The 73 and up B bodies have links like yours where the end of the bar mounts to the frame and the bar itself is supported by the links.
Finding usable ones like yours are hard sometimes.
Maybe you can get somebody to weld a bolt to that one to save it?
Re: Late B-Body Rear Sway Bar End Link Part Number? [Re: IMGTX] #3228773
04/23/24 01:22 PM
04/23/24 01:22 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
As some one else said . . . check with Firm feel...they show this for 1970 Chrysler front - the factory link looks like the same link you show for your rear link :
https://firmfeel.com/collections/19...way-bar-kit-1-1-4-w-factory-sway-bar-app
Good luck
what oe 70 C body front mount looks like
