Re: For Sale - Race Parts - 2nd Quarter
[Re: moparts]
#3230666
05/02/24 03:30 PM
05/02/24 03:30 PM
Posts: 70 norcal
JLaSalle
norcal
JW Ultrabell,flexplate and crank adapter to adapt a glide to big block mopar. $550 + shipping.Venmo or paypal ok.707-478-6302
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
[Re: dsd70bee]
#3231652
05/07/24 09:56 PM
05/07/24 09:56 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
New set of K1 4340 H-beam Big block Mopar connecting rods
7.000 length 2.200 rod journal .990 pin ARP2000 bolts (stock mopar width).
These rods allow offset grinding your stock 440 crank rod journals to increase stroke from 3.750 to 3.925 inches
The rods with increase stroke yield the following performance benefits.
1) Increase displacement of 20 cubic inches 2) Reduction in rotating weight (weight off crank journals/bearings plus light weight rod big end) 3) Improved rod/stroke ratio 4) Reduction in reciprocating weight (small end of rod plus lower compression height piston plus light .990 pin) 5) reduce rod bearing speeds
$585 plus shipping (I've had these several years and would likely be more than double this price today)
thanks
rapid340@yahoo.com
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Weiand 440 Tunnel Ram
[Re: Rapid340]
#3231838
05/08/24 10:25 PM
05/08/24 10:25 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
NOS Weiand 440 Tunnel Ram, Some light surface oxidation in spots, Never installed. $450 + Shipping , PM me here if interested
The only Carbs I care about are under the hood!
TTI 400-13 Step Headers A B E w T Bar
[Re: Swingin70]
#3232678
05/14/24 04:04 AM
05/14/24 04:04 AM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
2'-2 1/8' Step, Very Solid, Shiny Finish, Some Bluing, Evac Tubes and Breathers. Also fit RB Engine with RMS or other Coil Over. Were in my Demon with Rb and Stage 6 Heads
$900 Pick Up in Maryland DC Suburbs
$1200 new with $200 shipping
will add Photos
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
Aldan American Coil overs - Need rebuild
[Re: moparts]
#3234414
05/23/24 12:25 AM
05/23/24 12:25 AM
Posts: 149 Albert Lea, MN
GTX5877
Albert Lea, MN
Pair of Aldan American aluminum, single adjustable coil-over shocks, bearing mounts. 16.5" extended and 12 compressed, 14" ride height. Both leak and NEED Rebuild !! so not selling usable shocks. Over $500 new. AS-IS $100 + ship.
PM or email GTX5877@yahoo.com
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
Hooker 3” offset in/center out Aerochamber mufflers
[Re: hankcrank]
#3236347
06/02/24 06:01 PM
06/02/24 06:01 PM
Posts: 8,188 Plymouth, MI
Blusmbl
Plymouth, MI
Brand new, only test fit and realized they didn’t work with my TTI exhaust, were too close to my driveshaft. $100 for the pair, prefer Detroit local pickup.
Thanks, Nick Blusmbl@yahoo.com or pm here on Moparts. Thanks!
400/512 for sale
[Re: hankcrank]
#3237307
06/08/24 12:14 PM
06/08/24 12:14 PM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
512/400 low deck for sale. carb to pan $15k obo
This is a fresh build and has 3 passes on it.. Its based off a stock 400 block with 440Source internals. It is pump gas friendly at 10.7:1 and has the upgraded ARP 2000 bolts, Ultra light crank, and their girdle as well. Block is not filled and not partially filled...
Indy 325 heads upgraded to 2.19 valves and Comp T&D 1.5 rockers, Morel Lifters, Indy ported 4500 low deck intake. 1050 4500 carb, Milidon oiling system, Indy timing cover and valley cover, ARP damper, Milodon chassis oil pan, & Summit valve covers. MSD distributor
Cam card available upon request.
