Re: And this is why Alum G2 Hemi's are such a PITA [Re: mopar dave] #3226394
04/11/24 12:30 AM
04/11/24 12:30 AM
I've never raced or had hands on help on any brand aluminum drag race motor so I'm repeating what I've heard or been told by those that do race them, other brand non Mopar aluminum blocks work realcrazy grin
Re: And this is why Alum G2 Hemi's are such a PITA [Re: Cab_Burge] #3226596
04/11/24 11:22 PM
04/11/24 11:22 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, but what if i find my sleeves have moved up above the deck? My block has all of the rotating assembly in it, cam included. Can i just heat the block and torque the head down to press them back in?
Re: And this is why Alum G2 Hemi's are such a PITA [Re: mopar dave] #3226600
04/11/24 11:56 PM
04/11/24 11:56 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't think they will rise above the deck.
2011 Drag Pak Challenger
Re: And this is why Alum G2 Hemi's are such a PITA [Re: mopar dave] #3226631
04/12/24 04:25 AM
04/12/24 04:25 AM
Call the block maker and ask them if the sleeves are suppose to be above the block .002 to .003 cold so they will be flush or a tiny bit down with the motor running and warmed up, The KB Street hemi blocks were designed that way back when I built my street hemi block in the early 2000s shruggy
Re: And this is why Alum G2 Hemi's are such a PITA [Re: Cab_Burge] #3226671
04/12/24 08:40 AM
04/12/24 08:40 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
When i purchased the block the sleeves were .003 above the deck. Best Machine decked the block, but i have no way of knowing if they reset the sleeves before hand. Doesn't mention it on the receipt and they are no longer in business. The sleeves in this block only have a .001 interference fit, so they move easily with temperature changes. I should be ok, i'm just being mindful of the situation. I now understand the French gentleman in the video had that block polished and the block was recleaned after, heating the block and allowing the sleeves to move. Steve missed it and they had that sleeve drop issue.
