Re: 1965 Trunion front joint
[Re: cudaman1969]
#3226078
04/09/24 04:30 PM
04/09/24 04:30 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
My 65 440 with 600 HP 4 speed and its the original never been apart.Ive broke rears but the front just keeps going My 57 Chrysler had the same just replaced a bad boot on it Never a problem
Chrysler Firepower
[Re: dvw]
#3226128
04/09/24 07:57 PM
04/09/24 07:57 PM
Posts: 8,251 fredericksburg,va
cudaman1969
fredericksburg,va
Can't sat which yokes. I just test fit them. A 10" cut off wheel in a miter saw is slow but cuts them with no issue. you can see the rib im talking about. Doug. That rib is to keep the o-ring (a ribbed affair about an inch long) in the slip joint so trans fluid won’t run back out the splines. All the slip joints I have are smooth in the front half, no splines. If that trunion will hold up to a 600 inch Hemi I’ll use that trans in the 64.
