Mini starter question #3225397
04/06/24 11:39 AM
04/06/24 11:39 AM
California
mickm Offline OP
mickm  Offline OP
California
I have a mini starter on the road runner, couldn't tell you which brand.
It's starting (pun intended) to do the clicking thing, where most of the time it starts, but then will just click, and I have to release and hit it again until it grabs. Assuming it's the solenoid.
Are these things repairable, or are they basically throw away?
I guess the issue too is I would have to get it out, find the problem, and then order the part if it is.
Might be a bit of a time crunch to get that done and make it to spring fling.
Re: Mini starter question [Re: mickm] #3225398
04/06/24 11:43 AM
04/06/24 11:43 AM
okla.
sam64 Offline
sam64  Offline
okla.
It's the contacts that the plunger connects to complete the circuit. yes it is repairable.You can get the plunger/contact kit on Amazon for 14.00
Re: Mini starter question [Re: sam64] #3225405
04/06/24 12:15 PM
04/06/24 12:15 PM
California
mickm Offline OP
mickm  Offline OP
California
Re: Mini starter question [Re: mickm] #3225421
04/06/24 01:32 PM
04/06/24 01:32 PM
moparx Offline
moparx  Offline
plus, it's a super easy thing to do !
also, you may just find a little polishing of the contacts is all it needs. i have run into that several times over the years.
beer
Re: Mini starter question [Re: mickm] #3225429
04/06/24 02:21 PM
04/06/24 02:21 PM
I would check all conections, especially all the grounds and go from there, clicking sometimes and not clicking all the time tells you have a bad, lose or corroded conductor scope wrench up
Re: Mini starter question [Re: moparx] #3225501
04/06/24 10:01 PM
04/06/24 10:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
beer
^^^ this ...
Mick you can order the plunger but in the mean time pull it and open up the solenoid , you'll probably see it's pitted , clean it up and that may be all it needs?
Re: Mini starter question [Re: Cab_Burge] #3225523
04/06/24 11:46 PM
04/06/24 11:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Agreed
Especially so at the battery.
God forbid you have the repair a cable connectors at the battery as they are notorious for your exact issue beer
Re: Mini starter question [Re: JohnRR] #3225547
04/07/24 09:53 AM
04/07/24 09:53 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
^^^ this ...
Had a similar issue on the direct drive starter my 64 300 had. Ended up flipping the copper disc around and all was good.
