Page 2 of 4 1 2 3 4
Re: For Sale - Race Parts - 2nd Quarter [Re: moparts] #3226548
04/11/24 06:45 PM
04/11/24 06:45 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
Sold
Re: For Sale - Race Parts - 2nd Quarter [Re: moparts] #3226746
04/12/24 03:29 PM
04/12/24 03:29 PM
California
W
wedgedynamics Offline
W
California
Right and left rear brake calipers 2015 > Hellcat low miles with hoses $200.00 + shipping
wedgedynamics@yahoo.com Marty
Re: For Sale - Race Parts - 2nd Quarter [Re: moparts] #3226748
04/12/24 03:39 PM
04/12/24 03:39 PM
California
W
W
California
Hellcat 2015 ECU & Trinity tuner with disc & cable -Metco 2.75 pulley & 2 Gates green drive belts $200.00 for all free shipping.
Re: For Sale - Race Parts - 2nd Quarter [Re: moparts] #3226928
04/13/24 07:27 PM
04/13/24 07:27 PM
AndyF Offline
AndyF  Offline
Spare rockers - New Harland Sharp 1.60 rocker arms. I have a spare set of standard BB offset, and then one spare set with 0.650 offset for Victor heads. The 0.650 offset can be used with other heads too, but is usually used with Victor heads. $100 for all four or I'll split them up. PM me on the board, PayPal preferred for payment.
IMG_2553 (Medium).JPG (870 downloads)
IMG_2555 (Medium).JPG (868 downloads)
360 Ductile Iron 4 Bolt Main Cap Sets – New [Re: AndyF] #3227005
04/14/24 12:30 PM
04/14/24 12:30 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a sets of new ductile iron main caps available for 360 main blocks. These are Mopar Performance R Block caps. . The sets include all 5 main caps. The center 3 caps are 4 bolt main. I have installed these caps on a stock block before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a small block stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build. A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3 cap and #5 cap for the oil seal.
Price is $320 shipped in the lower 48 states.
Email procketrichard@hotmail.com for more information.
W2 Small Block Head Castings - New [Re: Rocket] #3227010
04/14/24 12:41 PM
04/14/24 12:41 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of Mopar W2 small block iron head castings. Valve angle is 18 degrees. No machining or port work looks to have been done. 3/8" iron valve guides installed in the heads from the factory. Casting number is P4532693. These heads are cast to use T&D or Jesel rocker arm systems.
I can send additional pictures for interested buyers.
Price is $1,100 plus shipping.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
15” Electric Fan & Controller [Re: Rocket] #3227012
04/14/24 12:45 PM
04/14/24 12:45 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a used electric puller fan and controller. The parts are in nice shape. Overall measurements are 16.75" x 16.25" x 4.0". The fan blades themselves are 15" diameter.
Price is $55 plus shipping.
Mopar Performance Small Block Pistons - New Incomplete Sets [Re: Rocket] #3227013
04/14/24 12:47 PM
04/14/24 12:47 PM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar Performance forged flat top pistons and pins. There are 3 different part numbers. There is not one complete set. Here is what I have.
P4876976 – Quantity of 6. Specs are 4.060” bore & ~ 1.67” compression height. These pistons are for a 0.060” overbore 360 with the stock stroke crankshaft or a 0.020” overbore 340 using a 3.58 stroke crankshaft.
Price for the 6 new forged pistons is $260 shipped.
P4876978 – Quantity of 4. Specs are 4.030” bore and ~ 1.67” compression height, These pistons are for a 0.030” overbore 360 with the stock stroke crankshaft
Price for the 4 new forged pistons is $160 shipped.
P5007413 – Quantity of 2. Specs are 4.030” bore and ~ 1.47” compression height, These pistons are for a 0.030” overbore 360 with a 4.00” stroke crankshaft.
Price for the 2 new forged pistons is $80 shipped.
W2 Econo Roller Rockers 1.5 Ratio Set of 12 - New [Re: Rocket] #3227014
04/14/24 12:51 PM
04/14/24 12:51 PM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar 1.5 ratio roller rocker arms for W2 econo heads. There are 4 left intake rockers and 8 exhaust rockers. I do not have any right rocker arms. All rockers are new. Some pictures of the rocker arms posted here.
Price for the 12 is $495 shipped to the lower 48 states. I will ship internationally for the extra shipping cost.
I also have some new spare 1.5 ratio exhaust roller rockers for W2 race heads. Contact me if you need any.
W2/W5 Exhaust Roller Rockers 1.5 Ratio - New [Re: Rocket] #3227016
04/14/24 12:59 PM
04/14/24 12:59 PM
CT
Rocket Offline
Rocket  Offline
CT
New Mopar Performance W2 /W5 exhaust roller rockers. I have quite a few of these so if you need more than one just ask.
Price is $38 each shipped in the lower 48 states.
Set of eight rockers is $280 shipped in the lower 48 states.
I will ship internationally for the additional cost.
Mopar Small Block Roller Rocker Kit 1.6 Ratio - New [Re: Rocket] #3227022
04/14/24 01:13 PM
04/14/24 01:13 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $490 shipped in the lower 48 states.
I will ship internationally for the additional shipping cost.
Big Block Mopar Erson Roller Rockers - New [Re: Rocket] #3227025
04/14/24 01:18 PM
04/14/24 01:18 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 16 new Erson big block Mopar roller rockers in their original box. These are 1.6 ratio and have needle roller bearings that ride on the rocker arm shaft. These rockers are USA made, and are very strong and are well constructed. They are not designed for pushrod oiling.
Note I do not have the shafts for these rocker arms. These rockers use an 11/16” hardened shaft that oil the rockers through the head pedestal.
These rocker arms are very difficult to find. Price is $480 for the 16 rocker arms shipped in the lower 48 states. I will ship internationally for the extra shipping cost.
Erson 2.JPG (948 downloads)
Erson 3.JPG (944 downloads)
Erson 4.JPG (946 downloads)
Erson 7.JPG (947 downloads)
Mopar Small Block Forged 4.060” Bore Pistons for 3.454” Stro [Re: Rocket] #3227028
04/14/24 01:20 PM
04/14/24 01:20 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 8 Mopar Performance pistons and wrist pins Mopar part# P4876973 for a 3.454” stroke crankshaft. Specs are 4.060” bore, 1/16, 1/16, 3/16 ring set, 0.984” wrist pin, flat top with ~ 5 cc eyebrows, listed by Mopar as 10.5 compression ratio. Compression height is ~ 1.72” per my measurement.
Price for the set is $480 shipped in the lower 48 states. I will ship internationally for the extra cost.
New BRC 4.030" Forged Pistons and pins for 3.79" Stoke Crank [Re: Rocket] #3227030
04/14/24 01:22 PM
04/14/24 01:22 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Appriximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
BRC 3.79 P1.JPG (946 downloads)
BRC 3.79 P2.JPG (942 downloads)
BRC 3.79 P3.JPG (943 downloads)
BRC 3.79 P4.JPG (942 downloads)
New MSD Digital 6AL Ignition & Chrome Ignition Box [Re: Rocket] #3227032
04/14/24 01:26 PM
04/14/24 01:26 PM
CT
Rocket Offline
Rocket  Offline
CT
New MSD Digital 6AL ignition module part #6425 $290
Used chrome ignition box $60
Prices include shipping in the lower 48 states. I will ship internationally for the added cost.
Re: For Sale - Race Parts - 2nd Quarter [Re: AndyF] #3227052
04/14/24 03:54 PM
04/14/24 03:54 PM
AndyF Offline
AndyF  Offline
Spare set of Crane 1.50 ratio, big block rocker arms. SOLD, thanks.
IMG_2549 (Medium).JPG (921 downloads)
Re: For Sale - Race Parts - 2nd Quarter [Re: AndyF] #3227053
04/14/24 03:56 PM
04/14/24 03:56 PM
AndyF Offline
AndyF  Offline
Set of Harland Sharp hold downs. SOLD, Thanks.
IMG_2558 (Large).JPG (918 downloads)
Holley Black and Blue Fuel Pumps + Regulator [Re: AndyF] #3227130
04/15/24 02:22 AM
04/15/24 02:22 AM
California
70Drop Offline
70Drop  Offline
California
I have a Holley Black Pump and freshly rebuilt regulator. I had these on my drag car for two seasons. Very good condition. No problems. I just needed to upgrade my fuel pump due to more power! $90 + shipping for both the regulator and pump. Summit sells the pump for $260 and the regulator for $46. My price for both the pump and regulator is just $90 plus shipping. I also have a blue pump that I've been using as my spare. I had it on the same car previously for about 6 seasons. This pump is $207 on Summit. Mine is $30 plus shipping. Best way to contact me is at mikeforsythe@yahoo.com
Black Pump only.jpg (867 downloads)
Pump + regulator.jpg (863 downloads)
Blue pump.jpg (866 downloads)
Summit.pdf (0 downloads)
Re: Holley Black and Blue Fuel Pumps + Regulator [Re: 70Drop] #3227259
04/15/24 08:29 PM
04/15/24 08:29 PM
Washington
skrews Offline
skrews  Offline
Washington
RCI 5 point racing harness, only used 4 times, SFI date expires in June, all hardware included
$40 shipped
Re: Holley Black and Blue Fuel Pumps + Regulator [Re: skrews] #3227480
04/16/24 02:28 PM
04/16/24 02:28 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Mopar Big-Block RB main bearing sets. Sets were installed bearing clearances checked and removed. PM me here if interested.
-Clevite MS-1795 V - Standard bearing size, $75 shipped
-King MB5116HP 001 (Sold)
King Rod bearing sets for Chevy Rod Journal Size. Both sets were installed bearing clearances checked and removed.
-King CR808HPN 010 - .010 undersize $50 shipped
-King CR808HPN 011 - .011 undersize $50 shipped
The only Carbs I care about are under the hood!
Page 2 of 4 1 2 3 4
