Oil pressure gauge line leaked --> need new carpet #3224949
04/04/24 09:40 AM
04/04/24 09:40 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Not sure why, cuz the connections are very straight forward, but the AutoMeter mechanical oil pressure gauge in the '73 leaked at the fitting during the initial start-up and soaked the d-a-mn carpet w/ 10w40. Nothing looked wrong, but...
Anyone trust electric oil pressure gauges instead of mechanical? I always wanted mechanical for "real time" response & readings, but am now wondering if I should swap it out.
$.02 either way appreciated. Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3224953
04/04/24 09:51 AM
04/04/24 09:51 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
initial start-up- Was the gauge new, was it a new install? If not how old was the line? Plastic/copper line? Id not let one bad time make me stray from a mech. gauge as much as it stinks it happened.
Ive had a few of the plastic line units develop a drip after many years so I just bought the line/fitting kit and all was good.
STOP POTATO HATE!
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3224955
04/04/24 09:52 AM
04/04/24 09:52 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
What kind of line are you using? I use stainless braided line, never had a leak. Bad fitting?
Re: Oil pressure gauge line leaked --> need new carpet [Re: rickraw] #3224956
04/04/24 09:53 AM
04/04/24 09:53 AM
Loudoun County, VA
Loudoun County, VA
New AutoMeter gauge with new AutoMeter braided line kit
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3224959
04/04/24 10:08 AM
04/04/24 10:08 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I’d make a new line & fittings. That supplied line is probably from chino
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3224972
04/04/24 10:57 AM
04/04/24 10:57 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Dawn Platinum and hot water washes it right out.
DAMHIK
Rich H.
Esse Quam Videri
Re: Oil pressure gauge line leaked --> need new carpet [Re: ZIPPY] #3224979
04/04/24 11:24 AM
04/04/24 11:24 AM
Loudoun County, VA
Loudoun County, VA
There's a brand new ACC carpet sitting in my basement waiting for me to pull the interior out... but I haven't been motivated to mess with it
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3224988
04/04/24 12:07 PM
04/04/24 12:07 PM
NC
440Jim Offline
440Jim  Offline
NC
The braided line and AN fittings should be the best. But something didn't go right...
Hard to say if it wasn't tight, debris in the AN flare, or fitting didn't seal to the hose. I would just cut off an inch and remake that end.
Re: Oil pressure gauge line leaked --> need new carpet [Re: 440Jim] #3224989
04/04/24 12:11 PM
04/04/24 12:11 PM
If you a 1/4 inch size line instead of the tiny standard size tiny line (CRS on that proper line size #: blush:) the oil pressure gauge will act like a tach, immediate response up
Re: Oil pressure gauge line leaked --> need new carpet [Re: Cab_Burge] #3224993
04/04/24 12:19 PM
04/04/24 12:19 PM
moparx Offline
moparx  Offline
i believe most oil pressure lines that come with [almost] any guage are 1/8".
aren't most a/n conversion hoses -3 ?
beer
Re: Oil pressure gauge line leaked --> need new carpet [Re: moparx] #3224997
04/04/24 12:27 PM
04/04/24 12:27 PM
I'm thinking they are 1/16 I.D., not 1/8 I.D.
The 1/4 inch I.D. copper line I used work like a charm, it was enlightening how rapid it would change readings when driving the car or revving the motor up out of gear up scope
I was told by a NHRA tech guy later to remove it and put the smaller ling back in that bracket car rant wink
Looking back I should have used a stainless covered #4 AN line and fittings up twocents
Re: Oil pressure gauge line leaked --> need new carpet [Re: Cab_Burge] #3225001
04/04/24 12:30 PM
04/04/24 12:30 PM
moparx Offline
moparx  Offline
yes, 1/16 inside diameter, 1/8" outside diameter Cab.
i was referring to the OD. sorry for the confusion.
i also like the larger OD tubing/hose for fast response time.
beer
Re: Oil pressure gauge line leaked --> need new carpet [Re: moparx] #3225005
04/04/24 12:41 PM
04/04/24 12:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Maybe bad fitting on the gauge end. Should be a clean -3 or -4 an male fitting there. Could be is buggered up a tad on the angle on the flare?
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3225028
04/04/24 02:09 PM
04/04/24 02:09 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Yep, same happened to me, the plastic line kinked and split a little allowing oil to drip onto the carpet, I went to an electric autometer, then to a Dakota dash. No issues, both are very responsive. IIRC the race scrutineers don't like oil lines in the drivers compartment anyway.
Re: Oil pressure gauge line leaked --> need new carpet [Re: Tig] #3225039
04/04/24 02:28 PM
04/04/24 02:28 PM
Loudoun County, VA
Loudoun County, VA
Just checked out AutoMeter's electrical options: a standard version about the same $ as the mechanical I have now, and a "hi zoot" version that's supposed to be very sensitive to pressure changes.... but also costs 3-4 times what the simpler gauges do
Will give the current fittings and hose a good close look and see if anything obvious is jacked up, then go from there
Re: Oil pressure gauge line leaked --> need new carpet [Re: Brad_Haak] #3225041
04/04/24 02:51 PM
04/04/24 02:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Well sheeet, there's your problem !!!
Re: Oil pressure gauge line leaked --> need new carpet [Re: Stanton] #3225103
04/04/24 08:26 PM
04/04/24 08:26 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
https://yellowjacket.com/wp-content/uploads/2015/01/High-Pressure-Control-Hose.pdf
Used one of these for 10 years on my oil pressure gauge, was left over from a job, works great. Its 45 deg flare.
