T/A 392 #3224660
04/03/24 08:25 AM
04/03/24 08:25 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Well I made the mistake of putting a Wide band o2 gauge on my 392 Challenger, at WOT its in the 11.6 afr range, now that I know this its driving me NUTS LOL, car runs great for being all stock 11.79@ 114.5 with drag radials, time for getting the stuff to do a tune on it GRRRR , looks like HP tuners is the best option.
Re: T/A 392 [Re: CSK] #3224667
04/03/24 09:04 AM
04/03/24 09:04 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
You may already be aware of this, but in case you're not:
- your car is new enough that you'll also need the OBD bypass link
- your ECM is locked from the factory; will need to send it someplace that can unlock it for you, or purchase a "blank" replacement outright
I've looked into "a tune" for my 1320, but haven't taken any steps in that direction since it's still under warranty thru EOY. Seems like there's a mix of people using the HP Tuners and DiabloSport hand-held tuners, plus something of an aftermarket for people who do custom "by mail" tunes.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: T/A 392 [Re: Brad_Haak] #3224673
04/03/24 09:33 AM
04/03/24 09:33 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Going to talk to Sound German, he is working on putting the Hellcat ecm,in the 392 ,,uses wide band O2's instead of the narrow ones we have in a 392, that way it will have ecm fuel control at all throttle ranges.
Re: T/A 392 [Re: CSK] #3224705
04/03/24 11:37 AM
04/03/24 11:37 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Another option is Geoff Turk - he has his Blackbird Performance up and running https://blackbird-performance.com/ - he has done some pretty impressive things in the tuning realm so far!
Re: T/A 392 [Re: DoubleD] #3224780
04/03/24 03:38 PM
04/03/24 03:38 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Get a hold of big 3 racing big rick has a new computor for the 2015 and up cars
Re: T/A 392 [Re: CSK] #3224883
04/03/24 09:19 PM
04/03/24 09:19 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I tuned my 2016 challenger scat pack when I had it.
To be honest it was a LOT of money to spend for ~20hp and bypass the 100s of hours of work put into the stock tune to keep it safe under all conditions by Chrysler engineering.
It's at that AF for a reason. Running it fat allows them to squeak in some more timing at 10.9:1 comp
Re: T/A 392 [Re: Brad_Haak] #3224932
04/04/24 07:26 AM
04/04/24 07:26 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
My brother has a 1320. He purchased a new OEM PCM . They put bigger injectors, E85 tune, light wheels and tires, smaller crank pulley. Made a huge difference. It's been 11.00 @ 125 in the 1/4 in really good air. I think it weighs over 4300 lbs with him in it.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: T/A 392 [Re: dizuster] #3224938
04/04/24 08:19 AM
04/04/24 08:19 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
I agree mostly with you , except the 392 has narrow band sensors, the HC has wide band, so do other performance newer cars, example of no wot fuel control is , yesterday it was 12.3 afr, the day before with different weather conditions it was 11.6 & thats not very fail safe , the car runs & drives awesome but this is a racing forum smile
Re: T/A 392 [Re: CSK] #3224952
04/04/24 09:51 AM
04/04/24 09:51 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I see a lot of names thrown around these days for "tuners"... HemiFever, Jay Greene, and lots of different shops offer their "talents". I don't know who really knows W T H they're doing... With these guys, I don't know how much is science and how much is "What happens if I push THIS button?"
I've been told a good "tune" for a Scat Pack is worth what was mentioned above, about 20 HP. And, no, it's not cheap when you need to drop the $ for a hand-held device, etc. Getting one w/ a safe "canned" tune that may be better than OEM but still leave power on the table is about $600 last I looked (e.g. DiabloSport). Add to that either the time and $ to have the original PCM unlocked or the cost to purchase an unlocked PCM outright and it's gonna hit $1K +/- ... ouch.
For me, I was looking for a couple of tenths so I could be pretty confident the car would run 11.99 or better under typical conditions. One of the local street car series has a 12.0 break between classes, which means you can flip a coin on whether I'm slower or faster depending on the time of year, etc.
Re: T/A 392 [Re: CSK] #3225119
04/04/24 09:56 PM
04/04/24 09:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
These PCMs and tunes are way way smarter than you think. They are watching and reacting to the weather conditions, water and oil temp, recent drive history, catalyst temps, knock sensors, etc...
It's not picking that AF on accident.
For what it's worth I work at Chrysler and had a lot of 1 on 1 time with the calibrators in my scat pack (392).
They don't need a wide band to know what the engine is doing in the NA range.
Just because the PCM isn't showing you the AF number you expect, doesn't mean it wasn't intentional.
Re: T/A 392 [Re: CSK] #3226245
04/10/24 12:10 PM
04/10/24 12:10 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
11.6 afr? You say the car runs great, so, the first thing I would look at is the gauge/sensor itself. It's Aftermarket, so right off the bat I don't put any faith in it.
Is it a brand-new gauge or was it used on another car you race? Is the sensor clean? Clean it with oven cleaner and put it back in, re-try it. If it's a generic Bosch or Denso order a new one and try it. Sensor positioning is highly important: Is the O2 sensor at the correct length from the head?
I had an O2 sensor go bad on a high performance application that would still run great at WFO but there's no "check engine" light for it: similar to your aftermarket gauge. The only way I figured what the problem was when soot started to show up in the pipes. 12.5:1 compression, so I run my own fuel mix with Lead in it, so, it ruined the O2 sensor. What do your exhaust tips look like? You run race gas in your 392?
I know this is a race forum, but what is happening with your fuel mileage in normal driving of your car? Did it take a dump? If not, and everything is otherwise normal I'd say the gauge is the issue.
Check the little things first before re-engineering the whole car. twocents
Finally, from an Engineering/Warranty standpoint: Dodge put millions of miles on that engine pre-production and if 11.6 at WFO is what's needed to protect it from burning up, that's what it needs. Don't mess with it. Tuner names mentioned here, (and I really like the "what happens if I push this button" reference wink ) have blown up plenty of Hemis. Especially "Hemi fever", Google him on the Ram Forums between 2004 and 2010 and see what comes up. rant
Mo' Farts
Moderated by "tbagger".
Re: T/A 392 [Re: Grizzly] #3226251
04/10/24 12:33 PM
04/10/24 12:33 PM
Nor here, Nor there
Dart 500 Online content
Dart 500  Online Content
Nor here, Nor there
When I had mine www.ostdyno.com was one of the best tuners for them, and can do it remotely
Re: T/A 392 [Re: Grizzly] #3226604
04/12/24 12:40 AM
04/12/24 12:40 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
if he blew up a bunch in the first few years he is probably one of the better ones by now...
Re: T/A 392 [Re: CSK] #3226605
04/12/24 12:43 AM
04/12/24 12:43 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
This is why you see such good gains from long tube headers, there is already too much fuel and doing something to pull in more air makes more HP. Now if it was 12.5 or 13 AFR from the factory it would probably get too lean and burn stuff up so the factory played it safe and added a little extra fuel.
Re: T/A 392 [Re: CSK] #3226699
04/12/24 11:04 AM
04/12/24 11:04 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
They do this with alot of vehicles for different reasons.
The SRT-4 crowd used to complain about running rich at WOT, and at the time I was acquainted with the development folks so I asked what the deal was.
On that specific car, I was told it was done for lifespan of the catalytic converter, leaner produced more heat than it could tolerate over the whole warranty lifespan.
Converters being real expensive to replace, even in 2006, but today would of course be worse.
They have to be really careful about that aspect of things.
It could be something similar or another combination of factors requiring the rich a/f, but believe me the guys calibrating that stuff aren't doing it out of ignorance.
PS this isn't top secret info as the same folks I asked were also on the srt forums of the day, providing the same answer.
Rich H.
Esse Quam Videri
Re: T/A 392 [Re: ZIPPY] #3226712
04/12/24 11:46 AM
04/12/24 11:46 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
This same reason applies to most efi cars. Run rich at wot to save the cats (and also more fuel during "cat overtemp" mode)
Re: T/A 392 [Re: INTMD8] #3226762
04/12/24 06:20 PM
04/12/24 06:20 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Cats get hotter with a rich mixture, my car is only rich at wide open throttle, not all the time, the wide band I am using is NTK, I am putting a flex fuel set up on it & this one is tunable & data logs with the wide band input, Baily's Hyperformance sells & installs this set up & they are very well known in the gen III world, Eflexfuel.com the Pro kit is the one that is tunable ONLY the fuel is . should pick up some power on E85 we will see
Re: T/A 392 [Re: CSK] #3226763
04/12/24 06:27 PM
04/12/24 06:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Some OEM EFI systems also add fuel over time. In a towing situation imagine being wide open for extended periods of time, they add fuel to keep rings and other things happy.
68 Barracuda Formula S 340
