Re: Steel shim head gaskets
[Re: cagebob1]
#3224687
04/03/24 10:41 AM
04/03/24 10:41 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
multi layered steel is best for iron block aluminum head don't worry about it. They are better than composite unless you have a bad surface finish.
[Re: hemienvy]
#3224831
04/03/24 06:36 PM
04/03/24 06:36 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
I thought the steel shims should only be used with iron block / iron heads. Composite, copper or any non stamp steel stock type factory head gaskets
[Re: Cab_Burge]
#3224915
04/04/24 02:55 AM
04/04/24 02:55 AM
Posts: 5,162 CT
GTX MATT
CT
I’ve been running them with aluminum heads for 10 years. I even removed a head and put it back together with a new gasket and did not re-surface. But i’m at 11:1 compression.
