Re: Tire/spring clearance: why not...
[Re: TJP]
#3224656
04/03/24 07:50 AM
04/03/24 07:50 AM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
To me it sounds like too much "rigging" for the potential problems and little gain I agree !! Do you have room for 1/2" spacers behind your wheels ??
[Re: topside]
#3226738
04/12/24 02:21 PM
04/12/24 02:21 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
[Re: TC@HP2]
#3227001
04/14/24 12:11 PM
04/14/24 12:11 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
Yeah, agreed - spring rate would need to be spec'd, and the narrower spring would arguably work harder, it was just a thought for a cheap way to gain clearance. It avoids modifying the rear axle perches. Many times, 1/2" makes all the difference...and yes, I realize that's a set-up line for a wisecrack, which I would reply with myself Dr Diff has a 1/2" kit, but I'd assume re-drilling is required for the axle's spring perches. I've previously found that the MP 3/4" kit doesn't really do much, but A-bodies are always dimensionally "casual" around the rear wheel openings. All of mine have been tighter on the right than the left, from 1970 to 1974 so far. Of course, the real cure is the "nuclear option" of the 2" deal, cutting the rails, welding in front boxes, and "while you're there", mini-tubs & narrowing the rear axle. But that's beyond the budget/time/whatever for a lot of folks.
[Re: topside]
#3227136
04/15/24 05:42 AM
04/15/24 05:42 AM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Yeah, agreed - spring rate would need to be spec'd, and the narrower spring would arguably work harder, it was just a thought for a cheap way to gain clearance. It avoids modifying the rear axle perches. Many times, 1/2" makes all the difference...and yes, I realize that's a set-up line for a wisecrack, which I would reply with myself Dr Diff has a 1/2" kit, but I'd assume re-drilling is required for the axle's spring perches. I've previously found that the MP 3/4" kit doesn't really do much, but A-bodies are always dimensionally "casual" around the rear wheel openings. All of mine have been tighter on the right than the left, from 1970 to 1974 so far. Of course, the real cure is the "nuclear option" of the 2" deal, cutting the rails, welding in front boxes, and "while you're there", mini-tubs & narrowing the rear axle. But that's beyond the budget/time/whatever for a lot of folks. The Dr diff kit listed above is at least honest about the clearance it provides even calling out the incorrect excessive claim of .75" Mopar Perf claims for their kit. Either kit does require some drilling into the frame rail to accommodate the welded-on nut of the front hanger and removal of the OEM perch and re welding a new set on. Just stating this- with everything installed and the new perches on and the U bolts clamped down to spec someone could weld the new perches to the axle tube very easily. If one is not a welder the car could be driven to a shop or if it's a non-road legal race car a mobile welder could stop out and lay a bead on the new perches.
Keep old mopars alive.
[Re: 2boltmain]
#3227138
04/15/24 05:53 AM
04/15/24 05:53 AM
2boltmain
Holland MI Ottawa
I remember a car mag playing with a Chevy Nova. They ground clearance into its leaf springs to provide clearance to the tire side walls. 2 locations on each side clearanced. I'm not endorsing this but I'm sure they were not the first to do this.
