Indexing QT Bellhousing #3224644
04/03/24 07:36 AM
04/03/24 07:36 AM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
I'm installing a used QT bellhousing on my 70 Duster with a 318. Transmission is an 18 spline A body four speed. The engine is in the car.
The instructions I found online recommend indexing the bellhousing to correct any misalignment between the engine and transmission. I understand that this is critical when using a TKX or TKO due to the tapered input shaft bearing. Is this process necessary when using a NP transmission with it's roller bearings?
I'm working by myself and it is impossible to rotate the front of the engine and watch the bell from the back. Thanks for any help or guidance!
1970 Duster 340 clone
Re: Indexing QT Bellhousing [Re: BrianT] #3224654
04/03/24 07:48 AM
04/03/24 07:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yes, it's 100% necessary - with ANY trans. Install the bell and dial indicator setup and start at a specific point - set the indicator at zero then rotate the crank 45* and take a reading. do this for every 45*. Do the math and make your adjustments to the bell then do it all over again. You won't be the first person to do this alone !! If you want to cheat, you could get away wiith only checking it every 90*.
Re: Indexing QT Bellhousing [Re: BrianT] #3224685
04/03/24 10:11 AM
04/03/24 10:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes you have to do it and buy these BEFORE you start .
RobbMc dowels .
Buy these from Robb Mc , summit sells lakewood branded ones like these and just a pair of those cost a little more than buying all 3 offsets from Robb.
The old lakewoods that are marked Mopar/Ford and NOT Mopar , they are .500 which is Ford , Mopars are .496.
Re: Indexing QT Bellhousing [Re: BrianT] #3224690
04/03/24 11:01 AM
04/03/24 11:01 AM
AndyF Offline
AndyF  Offline
Use your phone to take a video of the dial indicator while you turn the engine over. That is what I do.
Re: Indexing QT Bellhousing [Re: JohnRR] #3224895
04/03/24 10:45 PM
04/03/24 10:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
RobbMc dowels .
I agree with ALL said. if you remove the plugs you might be able to rotate the motor using the pressure plate bolts following the ARC of the FW with a box end wrench. One can also install the starter and use a remote switch beer
Re: Indexing QT Bellhousing [Re: TJP] #3224931
04/04/24 07:24 AM
04/04/24 07:24 AM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
Thanks for the replies and advice everyone. I guess I was looking for someone to tell me that it wasn't necessary when I knew in my heart that it was?
So far, the plugs are out, the block plate is on as is the flywheel. I will bolt the bellhousing on and get the dial indicator set up. I have a buddy who says he can come by this weekend to help spin the engine while I write down the readings. It seems pretty straight forward from there. I have watched numerous YouTube videos on the subject.
Thanks for the heads up about the size of the dowels. I was looking on Summit's page and they list Ford/Mopar as .500", but if you look at the reviews there are comments from the Mopar guys saying that are too tight and needed to be modified. This saved me a HUGE amount of frustration in the near future. I will order the correct dowels from the link provided above.
Hopefully, I'll update this thread later in the week with good news. Thanks again!
Re: Indexing QT Bellhousing [Re: BrianT] #3225024
04/04/24 02:04 PM
04/04/24 02:04 PM
MN
Droop69 Offline
Droop69  Offline
MN
Why do you have an 18 spline trans behind a 318? Just curious seems like way overkill appplication.
Re: Indexing QT Bellhousing [Re: Droop69] #3225040
04/04/24 02:46 PM
04/04/24 02:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Hell, why not ?!?! It's not like they're any heavier or anything !
Re: Indexing QT Bellhousing [Re: Droop69] #3225045
04/04/24 03:19 PM
04/04/24 03:19 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
I'm having Brian Hafliger at IMM build me a 340 based W2 stroker motor. It should be ready later this summer.
Re: Indexing QT Bellhousing [Re: BrianT] #3225052
04/04/24 03:50 PM
04/04/24 03:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Read above JohnRR told you where to get the dowels And they fit.
Re: Indexing QT Bellhousing [Re: NITROUSN] #3225077
04/04/24 05:41 PM
04/04/24 05:41 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
I did. That's why I thanked him for the info?
Re: Indexing QT Bellhousing [Re: BrianT] #3225124
04/04/24 10:14 PM
04/04/24 10:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
in my experience the QT's are closer to spec than the Lakewood's, normally only requiring a .007 dowel if any beer
Re: Indexing QT Bellhousing [Re: BrianT] #3225163
04/05/24 07:56 AM
04/05/24 07:56 AM
MN
Droop69 Offline
Droop69  Offline
MN
That makes sense!
Re: Indexing QT Bellhousing [Re: BrianT] #3225168
04/05/24 09:07 AM
04/05/24 09:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Glad I could help.
I think he might have missed that statement , I know sometimes I miss things ... getting old ...
Re: Indexing QT Bellhousing [Re: JohnRR] #3225267
04/05/24 05:27 PM
04/05/24 05:27 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
Glad I could help.
Aren't we all. I hope I can get this thing on the road soon and start making more memories.
Re: Indexing QT Bellhousing [Re: BrianT] #3225312
04/05/24 11:06 PM
04/05/24 11:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Glad I could help.
the question of the day is: Will you remember the memories 😂, Or will they be Memorex? ❓❓
This is an Alzheimer's test question 🙄
Re: Indexing QT Bellhousing [Re: TJP] #3226892
04/13/24 02:47 PM
04/13/24 02:47 PM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
Success! My buddy came by today and we spent the morning measuring and remeasuring. We found .032 total run out so we divided by two and got .016. I just ordered the .014 offset dowels from RobbMC at the link above. Thanks everyone for their help and input!
Re: Indexing QT Bellhousing [Re: BrianT] #3226950
04/13/24 10:28 PM
04/13/24 10:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Indexing QT Bellhousing [Re: BrianT] #3226997
04/14/24 11:51 AM
04/14/24 11:51 AM
moparx Offline
moparx  Offline
please keep us updated on what TIR you ended up with, using those dowels.
beer
Re: Indexing QT Bellhousing [Re: BrianT] #3227029
04/14/24 01:20 PM
04/14/24 01:20 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Did you also verify that the bellhousing's transmission mounting face is square to the back of the block? Mine are usually off a bit from square, and I use hardend prescision washers to adjust that.
