Page 2 of 3 1 2 3
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224291
04/01/24 02:47 PM
04/01/24 02:47 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
If I were chasing ET probably. I would be more inclined to spend $ on weight reduction if it were a onetime buy like a fiberglass bumper vs a "maintain/wear" item like a battery. Personally I wouldn't waste my $$ on a lightweight battery, but I'm a cheap bracket racer that can just change my dial.
Re: Would you spend $500 to drop 35 lbs from car? [Re: DusterKid] #3224294
04/01/24 02:53 PM
04/01/24 02:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
$500 for maybe .03 in ET? The rest of this "heads up" car would have to be maxed out. Bracket car? Not in this lifetime.
Doug
Re: Would you spend $500 to drop 35 lbs from car? [Re: dvw] #3224304
04/01/24 03:13 PM
04/01/24 03:13 PM
PA
moparacer Offline
moparacer  Offline
PA
Eh, I might go $500 to pick up a few hundredths. I try to qualify for the quick 16 at my local track and have missed it many times over the years by .02 or .03
I looked into 16V lithium and it was a lot more than 500 though. Till I bought a charger and different alternator I was way over $1000
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Would you spend $500 to drop 35 lbs from car? [Re: dvw] #3224305
04/01/24 03:14 PM
04/01/24 03:14 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug
Agree. Just adjust the shoe polish.
Last year, I had a battery crap out. Went to the parts store, and picked up a new one that dropped right in. Where are you getting a back up lithium at?
69 GTX 68 Road Runner
Re: Would you spend $500 to drop 35 lbs from car? [Re: JERICOGTX] #3224372
04/01/24 08:21 PM
04/01/24 08:21 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
AGM batteries will get you pretty close for a lot less than 500 Simoleons. My 8 pounder would spin a 15:1 ~ 560 incher over like it was a toy.
batteriesplus.com/battery/sla-sealed-lead-acid & AGM batteries
Re: Would you spend $500 to drop 35 lbs from car? [Re: Bubba] #3224380
04/01/24 08:47 PM
04/01/24 08:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by Bubba
YEP. Spent more than that on less.
That's a fact.
I've seen and heard too much to put lithium in mine. I don't even trust the little ones around the shop.
We have 30lb total worth of AGMs in the Stockers. Hold up pretty well.
Re: Would you spend $500 to drop 35 lbs from car? [Re: CMcAllister] #3224396
04/01/24 10:40 PM
04/01/24 10:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I spent 300.00 to add 150 pounds. Removed my fiberglass doors and went back to stock doors with wind up windows.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Would you spend $500 to drop 35 lbs from car? [Re: pittsburghracer] #3224399
04/01/24 10:48 PM
04/01/24 10:48 PM
Why?
Which car and what year are to doors for? Are they for sale?
Re: Would you spend $500 to drop 35 lbs from car? [Re: Cab_Burge] #3224405
04/01/24 11:33 PM
04/01/24 11:33 PM
PA.
"Little"John
"Little"John
PA.
Why?
Sold them probably 5-6 years ago.(1970 duster) I made this car old man friendly. I pull in the trailer and climb out the window
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Would you spend $500 to drop 35 lbs from car? [Re: pittsburghracer] #3224420
04/02/24 02:07 AM
04/02/24 02:07 AM
I winch mine in now, I bought and use a Super winch 4500 Lb rated single line winch now wrench
No climbing out of them for me tsk grin
I can't remember now how much it costs me to switch from the old heavy Crager SS steel chrome wheels the new lighter weight race Crager Super Tricks a long time ago work
Maybe near 500 for 4 back then including the longer lug nuts work
Re: Would you spend $500 to drop 35 lbs from car? [Re: Cab_Burge] #3224431
04/02/24 07:09 AM
04/02/24 07:09 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
5 hundred is a little much for me for 35lbs.And i try to weigh every thing that goes on and off this car.
Re: Would you spend $500 to drop 35 lbs from car? [Re: topside] #3224437
04/02/24 08:26 AM
04/02/24 08:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted by topside
I thought about a Braille battery for the new project, but decided to move the existing lead-acid unit to the trunk and put the weight to good use.
But adding a switch for it doesn't bug me.
As for driver weight: I've always been skinny - usually 160 lbs - so it's always seemed a curiosity to me when big round guys are worrying about car weight.
I'm not being judgemental, it's just something I've never personally had, though my younger brother did get the "weight gene".
But everyone I've known who's returned to a more proportionate weight has felt & performed better.
I moved mine to the trunk (lead acid) and picked up exactly nothing. It did clean up under the hood though and the car starts better than it ever did.
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224464
04/02/24 11:10 AM
04/02/24 11:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nah.
I do like the idea of a lighter weight battery, but the value is not there for what I want to do.
Rich H.
Esse Quam Videri
Re: Would you spend $500 to drop 35 lbs from car? [Re: justinp61] #3224466
04/02/24 11:13 AM
04/02/24 11:13 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Absolutely, and have spent that and hundreds of hours to shed 35 lbs, but still running a big AGM battery in the stock location. I would change to lithium, just want to be sure it is not a replace it every couple of years thing.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Would you spend $500 to drop 35 lbs from car? [Re: Hemi_Joel] #3224480
04/02/24 12:05 PM
04/02/24 12:05 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Originally Posted by Hemi_Joel
A good lithium ion battery supposedly has a built-in battery management system that will prevent the conditions that cause the battery to catch on fire. Of course that's no guarantee that there will never be a problem. But that's why it's a good idea for us to keep track of what brand of batteries have the fire. I have been using anti-gravity batteries with no problem and they claim to have a superior battery management system, such that you can use the cars alternator to charge it for street driving. I have done just that on drag week.
The more digging into the subject, the less I have confidence in the original type of battery I was considering. Even though I know someone who has used the same model I was looking at successfully for the last couple of years in the same car, the manufacturer specifically says to use only with a charging system of below what I know his and my cars put out. I don't know if he's playing with fire (literally), but I won't.
The lithium ion batteries that look to have built-in management systems aren't in the $500 range, either. The comparable AntiGravity model is $950 for a 30 lb weight savings, so the cost-per-pound just got doubled by looking at a more reliable option. Hmmm... not at this time.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224490
04/02/24 12:21 PM
04/02/24 12:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
BTW who sells a $500 lithium battery? FWIW we switched the Vette to a lithium last year to loose weight. We only had a 22lb Odessey ATV battery in the car. But when we went to the Lithium we also removed the 120amp alternator and the cables and wiring to it. It wa also a change to 16V from 12V. We saved about 28lbs...
Re: Would you spend $500 to drop 35 lbs from car? [Re: Al_Alguire] #3224492
04/02/24 12:24 PM
04/02/24 12:24 PM
Loudoun County, VA
Loudoun County, VA
XS Power; they have "racing" batteries that are way more expensive, but I was looking the XV series of lightweight stock-replacement batteries: https://4xspower.com/collections/xv-automotive
They state no more than 150A charging system, but a 6.4 Challenger/Charger has a 220A system. There's a guy w/ another Challenger 1320 who has been using one since 2021, but... whistling
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224501
04/02/24 12:39 PM
04/02/24 12:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Interesting, yeah their race batteries are substantially more for sure.
Re: Would you spend $500 to drop 35 lbs from car? [Re: Al_Alguire] #3224668
04/03/24 09:13 AM
04/03/24 09:13 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
For a race car without a charging system, I'd think a marine lithium battery would work. My fishing boat has a lot of electronics on it, with the Group 31 lead acid battery after four and half hours of fishing it would be down to 11.4v, after six hours my 90hp outboard would crank slow and the depth finders would go off when the OB was cranked. I installed a new Impulse Lithium All Purpose 105ah, now after seven hours my voltage is 13.1v and the battery still has 48% or so charge. it's pretty cool to look at my phone and see the voltage and state of charge on my battery. The new battery required a new charger too, with a 15% discount on the battery it and the charger were still over $1k. Impulse Lithium has the best warranty that I found when researching lithium batteries.
Re: Would you spend $500 to drop 35 lbs from car? [Re: justinp61] #3225995
04/09/24 10:24 AM
04/09/24 10:24 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i have not read the whole thing here, BUT YES i would sure spend 500 or more for 35lb weight savings !!!
....BAD A$$ STREET CAR.....
Page 2 of 3 1 2 3
