Page 1 of 3 1 2 3
Would you spend $500 to drop 35 lbs from car? #3224176
04/01/24 10:18 AM
04/01/24 10:18 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Lightweight lithium ion battery...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224180
04/01/24 10:26 AM
04/01/24 10:26 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
100%! But you need a high quality brand, and I never charge it unattended.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224184
04/01/24 10:43 AM
04/01/24 10:43 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I did on one of my cars. That was the least expensive weight reduction on the car I did. (cost per pound)
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224185
04/01/24 10:47 AM
04/01/24 10:47 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Sometimes it's not about the weight, but where the weight is in the car. The smaller package of the LI battery allowed me to put the battery in low and in the rear cargo bin.
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224192
04/01/24 11:04 AM
04/01/24 11:04 AM
Loudoun County, VA
Loudoun County, VA
XS Power XV series, IIRC
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224193
04/01/24 11:07 AM
04/01/24 11:07 AM
AndyF Offline
AndyF  Offline
Stop ordering the double cheeseburger for lunch and you will drop 35 pounds while also saving yourself $500
Then you take the $500 you saved from the cheeseburgers and buy the Li battery. Now you've dropped 70 lbs without spending anything
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224199
04/01/24 11:16 AM
04/01/24 11:16 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I had a friend pull this out of a very high dollar Super Stocker while warming up at the track. He has gone back to lead acid.
Re: Would you spend $500 to drop 35 lbs from car? [Re: 340Cuda] #3224202
04/01/24 11:29 AM
04/01/24 11:29 AM
PA
Harry's Taxi 2 Offline
PA
What brand?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224203
04/01/24 11:33 AM
04/01/24 11:33 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
No. It's going towards a dual fogger grin
Re: Would you spend $500 to drop 35 lbs from car? [Re: Tig] #3224204
04/01/24 11:36 AM
04/01/24 11:36 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
primer
'63 Dodge 330
11.19 @ 121 mph
Re: Would you spend $500 to drop 35 lbs from car? [Re: Harry's Taxi 2] #3224205
04/01/24 11:37 AM
04/01/24 11:37 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
What brand?
He said it was a Lithium Pro battery
Re: Would you spend $500 to drop 35 lbs from car? [Re: 340Cuda] #3224216
04/01/24 12:27 PM
04/01/24 12:27 PM
Loudoun County, VA
Loudoun County, VA
Yeah, I could stand to drop about 40 lubs... getting old sucks
"Thermal runaway" with a lithium ion battery can be pretty scary. I don't know how commonly that type of battery design has issues in automotive applications, but it does have me questioning whether that's the direction I want to go
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224224
04/01/24 12:35 PM
04/01/24 12:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can do it...I dropped 70lbs after a couple years ago. I definitely feel better.
As for a Lithium battery be very careful what you buy. Charging can be an issue, and running an alternator can be as well. All of them have a max voltage they can tolerate and need to take that into account with an alternator. We have had very good luck with Go Lithium batteries and alternators with regulators turned down to just under the for the battery
Re: Would you spend $500 to drop 35 lbs from car? [Re: Al_Alguire] #3224255
04/01/24 01:15 PM
04/01/24 01:15 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
A good lithium ion battery supposedly has a built-in battery management system that will prevent the conditions that cause the battery to catch on fire. Of course that's no guarantee that there will never be a problem. But that's why it's a good idea for us to keep track of what brand of batteries have the fire. I have been using anti-gravity batteries with no problem and they claim to have a superior battery management system, such that you can use the cars alternator to charge it for street driving. I have done just that on drag week.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Would you spend $500 to drop 35 lbs from car? [Re: Al_Alguire] #3224256
04/01/24 01:16 PM
04/01/24 01:16 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Losing 35lbs, don't think I would feel good at under 130 so gonna pass on that one smile
Re: Would you spend $500 to drop 35 lbs from car? [Re: Al_Alguire] #3224262
04/01/24 01:28 PM
04/01/24 01:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I thought about a Braille battery for the new project, but decided to move the existing lead-acid unit to the trunk and put the weight to good use.
But adding a switch for it doesn't bug me.
As for driver weight: I've always been skinny - usually 160 lbs - so it's always seemed a curiosity to me when big round guys are worrying about car weight.
I'm not being judgemental, it's just something I've never personally had, though my younger brother did get the "weight gene".
But everyone I've known who's returned to a more proportionate weight has felt & performed better.
Re: Would you spend $500 to drop 35 lbs from car? [Re: topside] #3224272
04/01/24 02:10 PM
04/01/24 02:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I used to feel the need to carry weight around for my job, not necessarily round smile But upon being done I was headed there. I am no longer a military contractor and just felt there was no reason to be as big a guy. Plus I am old now smile I still go 220 but I am 6'3" still smile
Re: Would you spend $500 to drop 35 lbs from car? [Re: Al_Alguire] #3224275
04/01/24 02:19 PM
04/01/24 02:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO Lithium Pros is one to avoid. I have seen to many who have had issues with them including me. Not fire issues with it just charging, battery life an unexpected failure as well as poor customer service.
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224281
04/01/24 02:33 PM
04/01/24 02:33 PM
pa
gregcharger72 Offline
pa
I use antigravity brand battery , Weighs 8 lbs and it is a group 24 size case. Battey and charger was $425 2 years ago. It runs my fan in between rounds with no issues . I like it and would buy another.
Re: Would you spend $500 to drop 35 lbs from car? [Re: Brad_Haak] #3224285
04/01/24 02:41 PM
04/01/24 02:41 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
YEP. Spent more than that on less.
Page 1 of 3 1 2 3
