Re: Would you spend $500 to drop 35 lbs from car?
[Re: dvw]
#3224304
04/01/24 03:13 PM
04/01/24 03:13 PM
Posts: 2,530 PA
moparacer
PA
Eh, I might go $500 to pick up a few hundredths. I try to qualify for the quick 16 at my local track and have missed it many times over the years by .02 or .03
I looked into 16V lithium and it was a lot more than 500 though. Till I bought a charger and different alternator I was way over $1000
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: dvw]
#3224305
04/01/24 03:14 PM
04/01/24 03:14 PM
Posts: 10,050 MN
JERICOGTX
MN
$500 for maybe .03 in ET? The rest of this "heads up" car would have to be maxed out. Bracket car? Not in this lifetime. Doug Agree. Just adjust the shoe polish. Last year, I had a battery crap out. Went to the parts store, and picked up a new one that dropped right in. Where are you getting a back up lithium at?
69 GTX
68 Road Runner
[Re: Bubba]
#3224380
04/01/24 08:47 PM
04/01/24 08:47 PM
Posts: 11,822 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
YEP. Spent more than that on less. That's a fact. I've seen and heard too much to put lithium in mine. I don't even trust the little ones around the shop. We have 30lb total worth of AGMs in the Stockers. Hold up pretty well.
[Re: CMcAllister]
#3224396
04/01/24 10:40 PM
04/01/24 10:40 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I spent 300.00 to add 150 pounds. Removed my fiberglass doors and went back to stock doors with wind up windows.
[Re: pittsburghracer]
#3224399
04/01/24 10:48 PM
04/01/24 10:48 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
Why? Which car and what year are to doors for? Are they for sale?
[Re: Cab_Burge]
#3224405
04/01/24 11:33 PM
04/01/24 11:33 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why? Which car and what year are to doors for? Are they for sale? Sold them probably 5-6 years ago.(1970 duster) I made this car old man friendly. I pull in the trailer and climb out the window
#3224420
04/02/24 02:07 AM
04/02/24 02:07 AM
Cab_Burge
I winch mine in now, I bought and use a Super winch 4500 Lb rated single line winch now No climbing out of them for me ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) I can't remember now how much it costs me to switch from the old heavy Crager SS steel chrome wheels the new lighter weight race Crager Super Tricks a long time ago ![work work](/ubbthreads/images/graemlins/custom/work.gif) Maybe near 500 for 4 back then including the longer lug nuts ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: topside]
#3224437
04/02/24 08:26 AM
04/02/24 08:26 AM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
I thought about a Braille battery for the new project, but decided to move the existing lead-acid unit to the trunk and put the weight to good use. But adding a switch for it doesn't bug me.
As for driver weight: I've always been skinny - usually 160 lbs - so it's always seemed a curiosity to me when big round guys are worrying about car weight. I'm not being judgemental, it's just something I've never personally had, though my younger brother did get the "weight gene". But everyone I've known who's returned to a more proportionate weight has felt & performed better. I moved mine to the trunk (lead acid) and picked up exactly nothing. It did clean up under the hood though and the car starts better than it ever did.
[Re: Brad_Haak]
#3224464
04/02/24 11:10 AM
04/02/24 11:10 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Nah.
I do like the idea of a lighter weight battery, but the value is not there for what I want to do.
Rich H.
Esse Quam Videri
[Re: Hemi_Joel]
#3224480
04/02/24 12:05 PM
04/02/24 12:05 PM
Posts: 1,202 Loudoun County, VA
Brad_Haak
Loudoun County, VA
A good lithium ion battery supposedly has a built-in battery management system that will prevent the conditions that cause the battery to catch on fire. Of course that's no guarantee that there will never be a problem. But that's why it's a good idea for us to keep track of what brand of batteries have the fire. I have been using anti-gravity batteries with no problem and they claim to have a superior battery management system, such that you can use the cars alternator to charge it for street driving. I have done just that on drag week. The more digging into the subject, the less I have confidence in the original type of battery I was considering. Even though I know someone who has used the same model I was looking at successfully for the last couple of years in the same car, the manufacturer specifically says to use only with a charging system of below what I know his and my cars put out. I don't know if he's playing with fire (literally), but I won't. The lithium ion batteries that look to have built-in management systems aren't in the $500 range, either. The comparable AntiGravity model is $950 for a 30 lb weight savings, so the cost-per-pound just got doubled by looking at a more reliable option. Hmmm... not at this time.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3224490
04/02/24 12:21 PM
04/02/24 12:21 PM
Posts: 19,402 Las Vegas
Al_Alguire
Las Vegas
BTW who sells a $500 lithium battery? FWIW we switched the Vette to a lithium last year to loose weight. We only had a 22lb Odessey ATV battery in the car. But when we went to the Lithium we also removed the 120amp alternator and the cables and wiring to it. It wa also a change to 16V from 12V. We saved about 28lbs...
[Re: Al_Alguire]
#3224492
04/02/24 12:24 PM
04/02/24 12:24 PM
Brad_Haak
Loudoun County, VA
XS Power; they have "racing" batteries that are way more expensive, but I was looking the XV series of lightweight stock-replacement batteries: https://4xspower.com/collections/xv-automotiveThey state no more than 150A charging system, but a 6.4 Challenger/Charger has a 220A system. There's a guy w/ another Challenger 1320 who has been using one since 2021, but... ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: Brad_Haak]
#3224501
04/02/24 12:39 PM
04/02/24 12:39 PM
Al_Alguire
Las Vegas
Interesting, yeah their race batteries are substantially more for sure.
[Re: justinp61]
#3225995
04/09/24 10:24 AM
04/09/24 10:24 AM
Posts: 4,703 On the parachute mount
n20mstr
i have not read the whole thing here, BUT YES i would sure spend 500 or more for 35lb weight savings !!!
....BAD A$$ STREET CAR.....
