For Sale - Big Block Engine - 2nd Quarter
#3223972
03/31/24 12:10 PM
03/31/24 12:10 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Re: Carter #9410s AFB Carbs 400 CFM (2)
[Re: 19Coronet66]
#3224013
03/31/24 02:36 PM
03/31/24 02:36 PM
Posts: 674 Ripley
BryanRad
Ripley
Pete Jackson Noisy Gear Drive – less than 500 miles $75 Big block water pump housing powder coated $50 Big block timing cover powder coated $25 Big block timing cover chrome $15 Factory chrome valve covers $35 Proform or similar chrome valve covers $20 Taylor spiro-pro plug wires big block Mopar $40 Miscellaneous Jegs hose and fittings $50 Mopar performance electronic distributor $80 Mancini Big Block Balancer MRE80013 – new $90 - SOLD
Parts located in Ripley, WV Price doesnt include shipping
Re: For Sale - Big Block Engine - 2nd Quarter
[Re: moparts]
#3224118
03/31/24 09:02 PM
03/31/24 09:02 PM
Posts: 5,617 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
Two new, unused big block head pipe to exhaust manifold flanges still in the packages. $15 for the pair.
Unused/unopened big block exhaust manifold stud kit. Although the bag is unopened, I can see some surface rust from humidity on some of the pieces. $40
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Single nipple oil breather with hose. $30
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
133 New radiator, heater hose and fuel hose clamp covers. Some chrome, some red anodized and some blue anodized. Various sizes. $75 for the lot.
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
TQ 9080s
[Re: 6PAX]
#3224129
03/31/24 10:07 PM
03/31/24 10:07 PM
Posts: 2,228 ILLINOIS
volaredon
ILLINOIS
Fitment shows 77 440 Clean but dusty, everything moves freely. Looks like it "could" go right onto an engine and run/ but not knowing exactly when it last did just that, I have to at least recommend it to be kitted before being bolted on and run again. Been on a shelf in my garage for who knows how long Asking $70. Plus the ride. Or local pickup. Preferably paid for by postal MO.
[Re: moparts]
#3224143
03/31/24 11:52 PM
03/31/24 11:52 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Big block cast iron passenger side exhaust manifold
Right hand manifold has a casting date of 3751074. It's also missing the heat control valve as shown in the photos. This one is $40 (plus shipping)
Needs to be cleaned up, but otherwise appear to be in fair enough shape with no apparent cracks. PM me for more photos. Located in West Sacramento.
440-1 Aluminum Heads Flow 363 cfm Intake $3800
[Re: moparts]
#3225369
04/06/24 09:45 AM
04/06/24 09:45 AM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Reworked Aluminum -1 Heads. Originally Done by Nic at Compu Flow. I had reworked by Burtonsville Performance Machine (Al Callway) after engine failure and have Not run. At this time, Exhaust valves Replaced and some intakes, New Roller Springs, Locks and Keepers, Chambers and Guides addressed as needed and surfaced. I just had Al recheck Spring Pressures- Set up at 1.98", 270#, .700" 630#, Coil Bind .800. Comes with NEW Manley Bolt Package Ran 9.28 in 3200# Demon w 499.
$3800 offer with Bolts, Can Ship
Also have TTI Low Deck 2-2 1/4 Step Headers available to Purchase and other Indy Top end Parts.
2 400 4 bbl engines with 727 Transmissions
[Re: moparts]
#3226361
04/10/24 07:30 PM
04/10/24 07:30 PM
Posts: 4 St. Louis, Missouri
69F8C500
St. Louis, Missouri
SOLD SOLD For sale: complete 400 4 bbl engines with 727 transmissions. Both are complete carb to oil pan. They are out of mid to late 70s C bodies, both have about 70K miles. Both have run recently on an engine run stand. $800 EACH. Located in Millstadt, Illinois (just outside St. Louis). If interested please contact Ryan at 314-504-0634 thanks SOLD SOLD
Big Block Throttle Cable Bracket
[Re: moparts]
#3226644
04/12/24 07:24 AM
04/12/24 07:24 AM
Posts: 4,161 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
Big Block Throttle Cable Bracket. Used, $30 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only! Call Steve 810-629-1097
